Tech question- head removal
Just a quick question, can I remove the head from a B16a in car, with out taking off the crank pulley? It looks like I have to get the lower timing belt cover off, and the only way is to remove the pulley, which sucks as I am almost completely apart and have absolutely no way to get that damn pulley off. I am trying to replace the headgasket.
Can I pull the cam gears off, with the belt around them and have any luck getting it back on like that, I have a feeling no...
Loosen the timing belt tensioner. There is a little cover for the bolt under the motor mount... 14mm hex head on the bolt.
Make sure hte motor is at TDC before you do this....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Noodles »</TD></TR><TR><TD CLASS="quote">One trick is to zap strap the timing belt to the cam gears in several places. This way you can slide the gears off and on knowing the timing isn't being adjusted.
Good idea!
I have always just marked it with a black marker on the cam gear and a white grease pen on the timing belt.
</TD></TR></TABLE>Good idea!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pmachan »</TD></TR><TR><TD CLASS="quote">Thanks, got it. Not an easy place to get at!
Also, on reassembly there is a hole on top of each cam rail (or cap, depending on vtec or not) that that lines up with a hole in the cam at TDC - drop a 5mm pin punch through the holes and the cam is now locked in at TDC, easy for getting the belt back on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">standard lefty-loosey, righty-tighty. no funny business on the hondas
cept on the DIFF!!!!!!!!!!!!!!
</TD></TR></TABLE>cept on the DIFF!!!!!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
only on LS, B16 and s2k's n0ob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol »</TD></TR><TR><TD CLASS="quote">only on LS, B16 and s2k's n0ob
Uh all other B series diffs have left hand threads too......way way way OT though
</TD></TR></TABLE>Uh all other B series diffs have left hand threads too......way way way OT though
