Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Teach me to launch...
Old Oct 8, 2001 | 12:57 PM
Jordan_4WS's Avatar
New User
Default Teach me to launch...
I have a 92 prelude SI 4ws w/ stock clutch. What is the best way to launch? Should I rev it to like 3k-4k or to like 5k-6k? And should I let the clutch out slow, or drop it fast? Which will be the most reliable and which will give me the best times?
Thanks, jordan
Old Oct 8, 2001 | 01:08 PM
r2x's Avatar
r2x
Default Re: Teach me to launch... (Jordan_4WS)
Before "it" starts again...
Launch for what type of racing? That makes a difference...
Old Oct 8, 2001 | 01:25 PM
Drew M's Avatar
New User
Rev it to 10k and dump it bro - you've got VTEC!
Wait - do you have an ASGM ver. III or higher installed? If not get one!
Old Oct 8, 2001 | 02:15 PM
Jordan_4WS's Avatar
New User
Default Re: Teach me to launch... (Cobra)
I dont have VTEC redline is 6500 and stock clutch.
I want to learn how to launch for both street racing (red light encounter) and 1/4 mile times.
Old Oct 8, 2001 | 02:25 PM
JG Luder's Avatar
Practice. Where's your main torque range? How much do you spin off the line when you launch at 5k as opposed to 3k? How much air pressure do you ahve in your tires?
Just play with it.
Old Oct 9, 2001 | 08:30 AM
rltrock's Avatar
New User
Default Re: Teach me to launch... (JG Luder)
This is a good question.
What about launching a Type R (stock) for autocross purposes?
Old Oct 9, 2001 | 10:06 AM
00R101's Avatar
Default Re: Teach me to launch... (rltrock)
I'd say its very grip dependent. On grippy concrete in the summer with already warm Hoosiers I launch at around 4500 with a quick slip and nailing the throttle. But on average macadam on street tires I launch at 3300 with the same foot technique. Bottom line is I try to go for a little wheelspin (slightly more than a chirp)
Old Oct 9, 2001 | 10:39 AM
4doorH22's Avatar
There are so many different combinations of cars, tires, and surfaces that there is no one way to do it. With four bangers that make their power high in the rev range, the goal is to spin the tires on launch, and have them hook up as your engine is entering the meat of it's torque curve. Once you're hooked up you'll be putting power to the ground through your motor's power peak. On each upshift, you want your RPMs to fall around your peak torque, no higher. So depending on your engine's torque curve, it's not always the fastest way to run the 1/4 mile bouncing off the rev limiter in each gear.
Old Oct 9, 2001 | 10:52 AM
SOHCArchangel's Avatar
Default Re: Teach me to launch... (4doorH22)
i can lunch...oh no, wait he said LAUNCH
Old Oct 9, 2001 | 12:33 PM
shamoo's Avatar
Will you make something up for me please?
This is correct. First you want to find out where your peak torque is and launch right below it. Slip the clutch fast and get just a little wheel spin, then as it catches, you'll be in your peak torque and then after that, it's all easy. It sounds easy, but it takes practice. Slipping the clutch that fast might cause you to either spin too much, bog, or even stall. Practice practice.
This is of course at the track, I'm sure you love your clutch too much to be doing this all the time on the street when you race someone.
Old Oct 9, 2001 | 02:27 PM
rltrock's Avatar
New User
Default Re: Teach me to launch... (00R101)
when you guys mean "quick slip", I assume you mean bring the pedal up quickly, but not let the pedal snap release -- right?
Also, If I'm looking to engage just below peak torque, then in the ITR, I would have thought that I would need to launch considerably higher than 4500 -- more like into VTEC?
Old Oct 9, 2001 | 03:23 PM
JG Luder's Avatar
where's that damn chirp thread when you need it.
Old Oct 9, 2001 | 04:38 PM
yeah and the pic of the fuzzy logic chirp controller, dam i gotta get ONE!!!!!!
papa5murf
Honda S2000
11
May 10, 2004 12:54 PM
b0wti
Mar 7, 2003 08:23 AM
SoulSurfer
Jun 25, 2002 04:22 PM
ezark
Nov 15, 2001 09:53 AM
