Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Summit Point Question
Old Mar 2, 2002 | 12:20 PM
sjasmund's Avatar
Default Summit Point Question
For those of you that have run there... what is the track surface like?
Is it easy or hard on tires? We reserved a couple of entries for the 12-hour race and we're trying to determine how many tires we'll need.
Old Mar 2, 2002 | 01:01 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Summit Point Question (sjasmund)
Plan on changing your fronts every 2 hours, and the rears maybe only once. Highly doubtful the right rear will ever need to be changed. This is assuming you're using something that wears like a Kumho. If you're talking about a Toyo RA-1, you can cut these numbers in half. If you're using Hoosiers, errr, I hope someone else is paying for them.
Should only have 1 brake stop.
Warren
Old Mar 2, 2002 | 01:32 PM
Honda318dx's Avatar
For a CRX, there are only 2 hard braking zones, for turn 1 and 5... Summit is pretty nice on brakes...
As for tires, warren knows more than I, he crews for the 12 hour all the time..
Old Mar 2, 2002 | 11:07 PM
sjasmund's Avatar
Default Re: Summit Point Question (Warren)
I run Hoosiers... that's why we're concerned about wear.
I've never run Toyo's on the ITA car. I ran them several years ago in ITC and they felt very similar to the Hoosiers but not as much grip. No experience with Kuhmo.
Old Mar 3, 2002 | 07:11 AM
Warren's Avatar
Wrong-Way Wang
If you are hell bent on running Hoosiers, bring the oldest, hardest, crappiest ones you've got. The surface isn't too hard on tires, it's just that it's a really long race.
You really won't know your tire situation for sure until you've made a few pitstops and checked out the tires that came off. It's hard to say, but I'll stick with my previous swag.
Warren
Old Mar 3, 2002 | 08:48 AM
Crack Monkey's Avatar
We usually bring 8-10 Kumhos per SRX-7. Usually only use 6-8. Brake stops will depend on car and pad compound. We can make the entire 12 hours on Hawk Blues at all corners, but just barely. If we use anything else in the rear, we need a brake stop.
The track surface isn't particularly abrasive. But your front left will wear out WAY before any others.
Old Mar 3, 2002 | 01:12 PM
.RJ's Avatar
.RJ
Default Re: Summit Point Question (Crack Monkey)
Will blues in the rear increase the tendency of the rear brakes to lock up first? Is it just something to keep an eye on when braking hard?
Ryan
SnlpeR
19
Jul 30, 2006 09:11 AM
black3door
Jan 22, 2004 10:30 AM
asmallsol
11
Aug 13, 2003 02:24 PM
nEoMuGen
Sep 7, 2002 04:17 AM
robbin
Jun 21, 2002 06:06 PM
