Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
spring size
Old Jun 20, 2006 | 06:04 PM
ewaugh's Avatar
Default spring size
This may be weird and somewhat unconvitential but here's what I'm thinking. It's past time to get rid of the Vogtland off-the-shelf kit. I want to use differnet spring rates but I'd like to try to save money by not going coilover just yet. My question is does anyone know what the stock inside diamater for the front and rear springs on a 91 civic is?
Old Jun 20, 2006 | 06:25 PM
JOE BD-0's Avatar
Default Re: spring size (ewaugh)
If my memory serves correct, My '89 Civic Si's stock springs tapered from 3 1/2" to 2 1/2" (not sure if OD or ID), and were about 545 lbs for the front. Rear did not taper though...Both were something like 10" long......Your '91 should be about the same....I'm sure "Tyson" knows......Good Luck
Old Jun 20, 2006 | 07:39 PM
ewaugh's Avatar
Default Re: spring size (JOE BD-0)
545lbs on the front stock? So it sounds like 400lbs would be too soft then?
Old Jun 21, 2006 | 08:33 AM
JOE BD-0's Avatar
yeah, it's either 545# or 575# I can't remember offhand and I'm still looking for the piece of paper that has that info on it.....400# may be a bit soft, but it all depends on the rest of your setup and application.
Old Jun 21, 2006 | 04:06 PM
ewaugh's Avatar
Well I was planning 400f/500r with sport valves koni's rear and bilstein's front. Sotck sways. Current auto-x and track day car but will be TT car next season.
Old Jun 24, 2006 | 09:08 PM
JOE BD-0's Avatar
Dude,
So sorry man but I just found out that I have given you some BOGUS info......I thought that the "stock" spring rates for my '89 Civic Si hatch were #575 front and #540 rear....THIS IS NOT TRUE!!!!!!! Sorry again, but my #'s are way too high (like me) and POSSIBLY were listed in kg's not lbs........Don't quote me though..........Sorry again....FYI.........I started with 450# front 650# rear on Koni double adjustables and will be going higher soon (with the spring rate that is).........Good Luck
Old Jun 25, 2006 | 06:53 AM
ewaugh's Avatar
no problem. That did sound kind of high. I haven't done anything with it yet.
I'm still trying to decide wether to get some springs alone, go with something like GC's on my shocks, or with these http://picperformance.com/stor...t=192
civexspeedy
Dec 1, 2013 08:30 PM
sakasaku
May 22, 2008 06:56 PM
madhatter07
May 13, 2005 12:35 PM
BABY NSX
Sep 4, 2003 07:42 PM
