Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spring rates, diff between FR & RR?
Old Apr 20, 2013 | 10:21 AM
Honda Type R's Avatar
Default Spring rates, diff between FR & RR?
I've searched a lot & found people running all sorts of different combinations. I've been wondering how to choose the amount of difference between front/rear. Also, how do I decide if I want it front heavy or rear heavy? I'm sure this has been covered but searching only came up with stuff like "what's rates should I get".
Thanks,
Frankie
Old Apr 20, 2013 | 12:37 PM
Xian's Avatar
Default Re: Spring rates, diff between FR & RR?
A lot will depend on the car and what it'll be used for. Beyond that, there are a ton of different ways to reach the same handling balance but with pretty disparate rate splits.
Old Apr 20, 2013 | 05:50 PM
It's a DC2 GSR with 24mm/22mm sways, 200lbs lighter, & it'll be used for back road street driving (mountain passes and such) & track duty. Not a daily driver at all. I'm not sure of the exact weight but I've removed roughly 200lbs. I've driven an EK coupe with 450/400 on yellows with 22mm/14mm sways & it's not bad but it has worn out tires so I didn't wanna push it. He's putting RE11's on it so I'll drive it then & see how I like it.
Old Apr 21, 2013 | 04:15 AM
Ev's Avatar
Ev
My 94 Accord set up for road racing has 800f/1000r. Many crx's I know of run 600f/800r.
The higher rear rates help balance out the push.
Old Apr 21, 2013 | 09:13 PM
FlewByU352's Avatar
Soon we shall see what it does
KiNGDEE206
Suspension & Brakes
Nov 12, 2014 09:23 AM
Iloveyourhonda92
Suspension & Brakes
23
Apr 21, 2012 11:32 AM
B-B-K
15
Jul 10, 2005 05:43 PM
b18crx
Nov 14, 2003 06:12 PM
Balrog
Mar 14, 2002 11:30 AM
