Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spring Rate Question
Old Jul 9, 2002 | 12:47 PM
brasilracing's Avatar
Default Spring Rate Question
Just a brief question. I am going to order GCs 350/400s for my 5th Gen Civic. Unfortunately, they don't have the 400s in stock and suggested a 380/450 combo.
Will I notice enough of a difference between the 400s and 450s and is it enough of a difference to wait until they get the 400s in stock?
BTW, this is an autocross/streetdriven vehicle and I am concerned with the streetability of the car. Thanks.
Old Jul 9, 2002 | 12:54 PM
Reid's Avatar
Global Moderator
Default Re: Spring Rate Question (brasilracing)
380/450
Hands down.
Old Jul 9, 2002 | 12:57 PM
bojangs's Avatar
New User
Default Re: Spring Rate Question (Reid)
combined with an itr rear sway would you still recommend 450 in the rear? seems like it may be a bit too tail happy.. maybe step down to a gsr sway or go with a lighter spring?
Old Jul 9, 2002 | 01:02 PM
Is 450 in the rear too stiff?
Old Jul 9, 2002 | 01:17 PM
Reid's Avatar
Global Moderator
I'm using 600/800 in a 1992 Civic Cx.
I'll be installing ITR swaybars shortly.
Old Jul 11, 2002 | 12:37 PM
Muckman's Avatar
Moderator in Chief
Default Re: Spring Rate Question (bigmouthcivic)
I just ordered GCs with 500f/400r. Is that good?
Old Jul 11, 2002 | 04:40 PM
GSpeedR's Avatar
Default Re: Spring Rate Question (Muckman)
Ummm...yes?
I plan on going with 380/400. I think that a 450 lbs rear rate is too much for normal street driving. It really depends on your tolerances and your shocks (ie. Konis vs. my Tokico HPs). Having a shock that can properly rebound/bump will make a noticable difference. Of course, I still haven't bought new tires, so what the hell do I know?
Old Jul 15, 2002 | 07:47 AM
Muckman's Avatar
Moderator in Chief
Default Re: Spring Rate Question (GSpeedR)
I wanted something very stiff but not too extreme. An autocrossing friend helped me with my setup. GC's 500f/400r with Koni Yellows.
My question is about shock/spring balance. Im concerned about rebound and bounciness. Im unclear about the difference of a softer or harder spring affects rebound on the same shock (Koni Yellows). Such as if Im using a stiffer spring will I get more or less rebound? Im thinking more because more weight is being supported by the springs instead of hte shock which damper rebound?
Any thoughts?
muddmonky
Suspension & Brakes
23
Apr 16, 2013 02:09 PM
xhatchracerx
Apr 16, 2004 04:28 PM
v67-gsr
Sep 24, 2003 11:50 PM
ActiveAero
Oct 4, 2002 08:22 AM
