Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
spring problem.. help
Old May 11, 2003 | 12:42 PM
REDMAN1322's Avatar
New User
Default spring problem.. help
after an event of hard racing i always change from my racing tires to my street tires like most of us do, but at the last event i noticed that my front passenger spring had a slight curve in at, just a mild bend.
i was wondering if this is bad, and what may have caused this
also is it ok to drive and/or race with this
there doesnt seem to be any problems driving or racing with the spring in its current condition
in fact i was only a half second away from first at my last event
any suggestions would be greatly appreciated
Old May 11, 2003 | 03:37 PM
CRX Lee's Avatar
Default Re: spring problem.. help (REDMAN1322)
Are the spring stock or aftermarket? Are their normal replacement spring size sitting on a factory perch or are they rqce springs with flat ground ends and a straight cylindrical side. More info is needed but as a general rule of thumb they shouldn't bow like that nor is it something that will likely make you crash on no notice.
Old May 12, 2003 | 02:28 AM
REDMAN1322's Avatar
New User
Default Re: spring problem.. help (CRX Lee)
they're stock springs on koni yellows
Old May 12, 2003 | 10:44 AM
REDMAN1322's Avatar
New User
someone must have some advice
Old May 12, 2003 | 10:52 AM
.RJ's Avatar
.RJ
Best to snap a picture.....
are they bent like in a half-hourglass shape? or bent noticeably left to right...
Old May 12, 2003 | 06:09 PM
REDMAN1322's Avatar
New User
Default Re: spring problem.. help (.RJ)
u can barely even notice the bend, the only way way i noticed is that the shock is closer to the spring near the middle of the spring
Old May 12, 2003 | 07:27 PM
CRX Lee's Avatar
They are just old, low rate springs that are showing some use. I wouldn'd freak about it but a set or good performance springs would make a nice upgrade before long. Take 'em off, salute 'em for a job well done and put on some sane performance springs.
Old May 12, 2003 | 08:04 PM
REDMAN1322's Avatar
New User
thanks
Old May 13, 2003 | 07:40 AM
GRM Scott's Avatar
25 Year Member
you know what, i had stock springs on koni yellows on my GS-R, and i think they did the exact same thing...but only when unloaded. When the car was on the ground, the springs were straight under load...i recall being satisfied with something about it and not worrying about it, but i can't for the life of me remember what that was. Still get some good rates on there anyway
JDM04Si
Aug 29, 2009 09:15 AM
ITRtist
Suspension & Brakes
13
Apr 14, 2007 08:19 AM
KOREAN
Suspension & Brakes
Dec 5, 2006 01:14 PM
toEknEEg
Jul 20, 2003 11:03 PM
CRX Lee
Feb 28, 2003 08:54 AM
