Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Should I continue like this?!
Old Mar 11, 2004 | 06:05 PM
LX4CYL's Avatar
Default Should I continue like this?!
I've done my 1st 7 autocrosses on my nice AVS ES100s, but after an unfortunate accident I destroyed 2 of my aftermarket wheels+tires. I don't plan on putting them back on (replacements) until summer, neither did I plan on buying a cheap set of wheels+azenis for auto-x until summer when I got home from college.
So, at this past autocross, I ran on my 195/65-15 Michelin Energy MXV4s that came with the car. Most of you agree that these make good tire swings, but I'm not sure if they'd work as street tires, which is what I think what Michelin had in mind for them.
I really hated they way the tires squealed when braking/turning/accelerating, and quite honestly, I hate driving on them.
I most likely will be stuck with them for the next 4-5 autocrosses, so do you guys think it's worth killing cones and making noise for this long? Will it really help my learning curve or am I just wasting my time?
Modified by LX4CYL at 3:22 AM 3/12/2004
Old Mar 11, 2004 | 07:49 PM
Bambooseven's Avatar
Default Re: Should I continue like this?! (LX4CYL)
running bad tires will only help you understand why you want to run good tires when you switch back over. It doesn't sound like you have much of a choice anyway for the time being, run em, untill you can afford new tires/wheels
Old Mar 11, 2004 | 07:53 PM
LX4CYL's Avatar
Default Re: Should I continue like this?! (Bambooseven)
I know, I'm just hating the way the car plows and stuff. Just wanted to be sure since I can easily but 2 new tires for the 2 replacement wheels I bought last month, and autocross with the 2 old tires up front for the time being.
This better help my learning curve otherwise there will be a set of MXV4s burning in my front yard this summer
Old Mar 11, 2004 | 10:13 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LX4CYL &raquo;</TD></TR><TR><TD CLASS="quote"> do you guys think it's worth killing cones and making noise for this long?</TD></TR></TABLE>
Yes! Especially if you're new to the sport.
-travis, who may have learned more about the dynamics of his car in the rain than in the dry, and that's saying a lot in the desert...
Old Mar 12, 2004 | 09:41 AM
FormulaIntegra's Avatar
Default Re: Should I continue like this?! (travis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">
-travis, who may have learned more about the dynamics of his car in the rain than in the dry, and that's saying a lot in the desert...</TD></TR></TABLE>
I will wholeheartedly second you on this one.
Try really bad stock tires that have meltied down to nothing after 2 HPDE weekends, in the rain. Imagine the Cingular cell phone icon and rotate it 45 degrees....that's what my traction circle turned into. The car would only allow 1 driver input at a time (acceleration only, no steering, or turning, but no trailbraking or accel) but it taught me a whole lot about what a seriously understeering car feels like, and knowing what a car feels like when it's going into the toilet can save your *** somtimes.
Old Mar 23, 2004 | 10:34 AM
LX4CYL's Avatar
Well, I went to a BMWCCA event this past Sunday, and I did MUCH better I actually got compliments on how well I did with those tires
BTW, according to the sidewall markings, I can't go higher than 44PSI. I set it at 44PSI, and it didn't roll over to the sidewall, but all of the "wear" consists of a 1-2cm wide band near the edge. Shuold I decrease the pressure a little to even it out? I'll use the glass chalk on my next auto-x (Auto-X #10)...
Old Mar 23, 2004 | 11:01 AM
fireant's Avatar
any room for camber adjustment on them there Accords?
Old Mar 23, 2004 | 11:11 AM
LX4CYL's Avatar
Default Re: Should I continue like this?! (hatch2k)
not stock, no I only plan on doing 6 more autocrosses on these tire tops, so a tire rotation after the next one should help...
Maybe I should just get some SPC front balljoints early?
Old Mar 23, 2004 | 11:15 AM
Crosser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LX4CYL &raquo;</TD></TR><TR><TD CLASS="quote">BTW, according to the sidewall markings, I can't go higher than 44PSI. I set it at 44PSI, and it didn't roll over to the sidewall, but all of the "wear" consists of a 1-2cm wide band near the edge. Shuold I decrease the pressure a little to even it out? I'll use the glass chalk on my next auto-x (Auto-X #10)...</TD></TR></TABLE>
The wear you are referring to is do to lack of negative camber. You are kind of stuck with that running a stock car. Some cars are allowed to run crash bolts based on the Factory Service manual that will allow them to get more negative camber. I would suggest rotating the tires front to rear every event this will help distribute the wear between the tires.
Marking the sidewall is a simple indicator of how much your tire is rolling over. If they are not wearing to the very corner of the tire where the tread meets the shoulder, then lower the pressures in 2 psi increments.
Old Mar 23, 2004 | 11:24 AM
Sean O'Gorman's Avatar
All of my autocrosses when I started in 2002 were on Michelin MXV4s. If I could do things over I wouldn't do a thing different except hit more races (I only did 3 events in 2002 before buying Victoracers) on those street tires.
Old Mar 23, 2004 | 11:33 AM
LX4CYL's Avatar
Default Re: (Sean O'Gorman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crosser &raquo;</TD></TR><TR><TD CLASS="quote">The wear you are referring to is do to lack of negative camber. You are kind of stuck with that running a stock car. Some cars are allowed to run crash bolts based on the Factory Service manual that will allow them to get more negative camber. I would suggest rotating the tires front to rear every event this will help distribute the wear between the tires.
I think I may have a touch of positive camber on one corner; can't remember which one I will try and see if reducing the pressure wil spread the wear out a bit, since it's not close to the sidewall...
Old Mar 23, 2004 | 11:38 AM
DsITR's Avatar
Default Re: (LX4CYL)
Put the 2 good AVS's up front... the michelin minivan tires in rear..
Wheeee
Old Mar 23, 2004 | 11:42 AM
LX4CYL's Avatar
Default Re: (DsR)
I did a practice and an autocross with 225/40-18 ES100s up front, and the 195/65-15 MXV4s in the rear. Let's just say that it was a bit loose
Old Mar 23, 2004 | 11:50 AM
MightyMouseTech's Avatar
Seat time is seat time. It doesn't matter what tire is on the car to learn car control. In fact, the slipperier the rubber, the lower the limit, the easier it is to learn how to drive the limit.
Old Mar 23, 2004 | 02:15 PM
Evan55's Avatar
Default Re:
yokos up front, michelins in the back.
car control is a good skill to learn too!
Azxster
Feb 21, 2006 02:11 PM
mickey513
Nov 18, 2004 09:00 AM
Discosteak
Jan 19, 2004 01:30 PM
CivicHB_92
56
Feb 27, 2003 09:28 AM
LOKTiN
Sep 23, 2002 05:34 PM
