is this safe?
so is it possible to use my Sparco 4 point harness with an Autopower Race Rollbar with a harness bar? So the Sparco harness would go over the harness bar and then down to the floor?
An Autopower with an integrated harness bar is the end mounting point for your shoulder belts. This puts them at a proper angle, as described above. Here's an example from my car:
Hope that helps,
Jon
Schroth
Ah, there's the problem. Schroth = unsafe garbage, IMO.
Joel
[Modified by JoelG, 4:19 AM 3/8/2003]
This is your life we're talking about.
My .02.
getfast.
thanks for the picture. It sure helped, but I am still wondering if I can use my Sparco 4 point harness once I get my roll bar or do I need to buy a new harness that will mount to the harness bar?
what type of harness do you have? IF its a 'street' harness that looks like this:
Or this:
Then you will need a new one that is 3", SFI approved and has either a latch-link or camlock that looks like this:
And mount them with these with backing plates
(i.e. not to the rear seat belt mounts)
Or this:
getfast,
could you take a picture of the rear mounting points for your roll bar? does it mount to the front of the rear tower? would I have to remove my Spoon rear tower bar?
Someone already answered this on another thread, but I just want to be 100% sure. Thanks!
.RJ,
the harness I have is the firts one. So why do they even offer those harnesses?
.RJ,
getfast,
.RJ,
Hmmmm, Schroth = unsafe garbage? How do you figure? That company makes nothing but harness belts, its their only business. They make them for cars, planes, helicopters, rollercoasters, etc. I'd think they would know more about them than anybody here on Honda-Tech? No? Its up to the driver to know how to use them properly, and every belt comes with detailed information on how the belts should be used. Since Schroth does testing on the belts, I'd think their recommendations would outweigh anybody spouting opinions on a messageboard. Now, if you've done extensive testing on these belts and can prove their instructions wrong, then I stand corrected.
To restate, Schroth = probably makes perfectly fine belts, I don't have any idea. 4-points on track = bad idea. And yes, I know why, but no, I haven't done any "testing", and I don't plan to.
So, the poster I replied to said that "The Manufacturer" (Schroth) said that it is acceptable to mount belts to the rear lap belt bolts. That is in direct violation of the SFI regulations as-is due to the angle. So -- WTF? I still distrust Schroth!
Maybe we're all talking apples and oranges, but here's my final take: The ONLY 2 types of belts I recommend for a street or track car are (1) stock factory belts or (2) SFI rated 5 or 6 point harnesses with rollover protection. I will stand by my original comment that everything else which does not fit in these categories is garbage, IMO. I perform tech inspections for our HPDEs and Time Trials, and I will fail anything else that comes along.
Mike
Unfortunately there are instructors and porsche/bmw drivers that think these schroth harnesses and harness bars are a wonderful idea (at NASA-Va events at least)
They're fine until you roll it.
Anyone know why the Schroth belts are a factory option on Euro-spec BMWs? Of course the easy way out is to say "because they can make money that way," but I'm curious if they offer any safety-related argument for offering the belts.
I've used the Schroth Rallye-series belts at autocrosses in other cars and found that they will ride up into the ribcage if not adjusted perfectly. Even then they will tend to ride up if you didn't *really* get them tight and in the correct order.
I understand that the angle of the rear strap is critical to avoiding spinal injuries. Some folks have mounted the tail strap to the rear shoulder belt anchor on the C pillar. Anyone have experience with this style of mounting? Want to comment?
Of course the one thing we seem to be missing from all these "discussions" about harnesses (read: newbies asking and RJ telling them why it's bad) is actual crash experience. Has anyone crashed with one of the various 4-point belts? What happened? How did the belts work? Can you compare that experience with a crash with regular stock belts?
-Adam (who isn't trying to be a smart-***, but seems to hear this same conversation repeatedly...)
When i had my incident at summit last year, my belts worked completely as intended and i had no ill-effects afterwards. This was not a high speed crash, but i will be installing a roll bar in the integra very soon for this reason.
isn't schroth the people that actually make sparco's belts?
That would be TRW Sabelt, of Italy, IIRC.
Jon
Jon
whoops......wrong "s" company........thanks for the correction
No prob... I only remembered because a) Sparco and Sabelt are both Italian, while Schroth is German IIRC; and b) because a Ferrari racecar I was recently drooling on wore harnesses with both Sparco and Sabelt logos stitched into its harnesses, so there must be a correlation.
Jon
ps- Sabelt also made a bunch of camlock harnesses for USA's own Racer Wholesale
getfast,
Most bolt-ins mount there. Custom is another story.
It is a standard Autopower bolt-in so yes indeed (for this particular Nissan application at least) it bolts to the front of the rear strut towers. Most (if not all) of the similar Autopower products I've seen do just that. Not custom by any means, but they serve their purpose well enough IMHO... better than no rollover protection if nothing more
Hope that helps-
Jon
i wonder why my sparco belts don't say anything about being made by Sabelt
for the person wondering if they can still use their sparco belts when they put in the cage......this is the best thing about sparco belts if you ask me (assuming other companies don't have the same offer); with sparco, you can just order a lap belt, just a shoulder belt, just a sub belt, etc....... so, if you want to use your rollbar to attach your harness to, then you can just buy the shoulder belts for $40 or whatever it is instead of $200+ for a whole new set.
He said he has a harness that looks like this:
The belt width is too small, is not SFI approved, and the latching mechanism is something that looks like it came with a toy for a 3 year old.
You cannot use any part of that harness on track. Well, you should not at least.
These belts are pretty bad for anything...every company makes a set too Momo, sparco ,schroth...I think OMP too.
When you pull down on the shoulder straps the lap belts will ride up onto your stomach where you don't want the belt to be...at least that was my experience with them.
This is a great discussion. I was considering a Schroth Rallye 4 belt, (which has tail straps that are mounted to the rear seat bolt location.) I think a Rallye 3 would be a better choice as the rear tail strap is mounted to the C-pillar, and thus parallel to the ground.
I have a 98 Prelude and at first I thought the Rallye 4 would be the only application, but if I remove the panel on the c-pillar I can have access to the c-pillar bolt.
I do auto-xing and Solo trails, thanks for all the information you all have given about the dangers in using a harness on the track. Needless to say I will use my factory belt on the track until I get a roll cage, and the harness only on the auto-x course.
Another trick you can do is buy a lapbelt from a camlock harness (just the lapbelt) and mount it just behind the seat on the floor - it will hold you in place better than one of the schroth belts will, when used along with your OE belt.
[Modified by Brett@SoloRacer.com, 10:06 AM 3/9/2003]
