Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
IT rules?
Old Aug 13, 2002 | 02:38 PM
sicivic's Avatar
Default IT rules?
Is there a website online where I can find out all the rules regarding IT series and the allowed mods to cars in the different classes. I tried searching and didn't find anything. Also, websites where people post about selling IT cars and other racecars. Thanks
Old Aug 13, 2002 | 02:45 PM
yoshi234's Avatar
I shoot brides
Default Re: IT rules? (sicivic)
Here
Old Aug 13, 2002 | 02:50 PM
Tyson's Avatar
Default Re: IT rules? (yoshi234)
no, the rules are not there either and there is no online IT rules to my knowledge. you have to buy a gcr. but you can check the classification on your car here:
http://toyota.shults.com/cgi-bin/scca/scca.cgi
generally tho, IT is open suspension and stock engine internals but open intake and exhaust. there MANY rules in between, which Knestis will attest to, but like i said, youd best get a GCR for yourself.
Old Aug 13, 2002 | 03:09 PM
ITACivic's Avatar
Default Re: IT rules? (Tyson)
Having the rule book can prevent you from buying the wrong parts.
Old Aug 13, 2002 | 03:24 PM
Knestis's Avatar
I mooched off of others' rulebook last year so don't mind answering specific questions, now that I have one of my own. You have to agree to follow rulebook karma though, and buy your own for next season...
What can I tell you?
Kirk
Old Aug 13, 2002 | 03:45 PM
sicivic's Avatar
Default Re: IT rules? (Knestis)
Where can I buy a rules book?
Old Aug 13, 2002 | 05:01 PM
CivicFerio's Avatar
The SCCA General Competition Rule book costs $25. You can call SCCA headquarters (303-694-7222) to order one.
Charleston
Old Aug 13, 2002 | 05:02 PM
Knestis's Avatar
Go to http://www.scca.org and get the merchandise order phone number. It takes a few weeks and costs - I think - $45 plus shipping. It is all of the rules for all of the club racing categories.
K
Old Aug 13, 2002 | 06:04 PM
Crack Monkey's Avatar
No webiste, just ordering the paper book (which comes with rules in pdf on CD).
Basically:
Tires: any DOT
Wheels: stock diameter, width depends on class (ITA and ITS are 7")
Brakes: stock hardware, pads fluid lines free
Control arms: stock
shocks: free, but only two adjustments, no remote resevior
springs: free. sleeve type coilovers only (no "full coilovrs")
bushings: free, as long as chassis and control arms are stock
exahust: free
intake: free in front of TB/MAP/MAF/Carb (whcihever is more upstream). no ram air.
radiator: free, fit in stock location
oil cooler: free
fuel tank: cells allowed
fuel system: pump, reg, lines free. injectors stock
engine: FSM rebuild specs, basic port matching
ECU: may be chipped. No stand alone engine management
ignition: stock dist housing, internals free. dist must control timing and distribution of spark (except on factory direct fire and crank fire systems)
interior: gutted. passenger door glass remains. dash remains. driver door gutted only to make room for NASCAR bars. Guages, shift ****, pedal covers all free.
safety: roll cage to GCR spec, fire suppression system, kill switch, window net or arm restraints. windsheild clips and rear glass straps allowed. hood/trunk pins allowed.
edit -
swaybars: free
traction bars: free (this is a big one for solid axle cars)
glass sunroof must be replaced with metal cover. Metal sunroff may remain if held in place securely (bolts, pins, straps).
[Modified by Crack Monkey, 7:06 PM 8/13/2002]
Old Aug 13, 2002 | 07:08 PM
Ausmith's Avatar
Default Re: IT rules? (Crack Monkey)
Clutch, diff, and final drive are also open.
Old Aug 13, 2002 | 07:38 PM
sicivic's Avatar
Thanks
JDM.K24
Jul 5, 2009 12:52 PM
twilightprotege
Welding / Fabrication
25
Mar 31, 2006 05:05 PM
EliteRides
Mar 16, 2006 06:08 AM
keithg
Dec 22, 2004 06:22 PM
Whitegsr2000
May 7, 2003 11:03 AM
