Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rotors
Old Jan 20, 2005 | 06:38 PM
naman's Avatar
Default Rotors
What rotors do you guys use? By you guys I mean Honda Challenge, ITA, ITC, etc.
Have heard a lot of you use Autozone rotors.
Old Jan 20, 2005 | 06:40 PM
EdoMoto's Avatar
Default Re: Rotors (naman)
I use $17 China rotors they work great.
Old Jan 20, 2005 | 06:45 PM
FlyZlow's Avatar
Yep. Pretty much just OEM replacement crap. In H2-H5, the rotor has to be same size/material/etc as stock, so pretty much any stock replacement will do. Plus, with only 2000 lbs and 130 hp, you get plenty of braking power out of stock rotors, crappy pads, and 1 piston calipers. I'm sure some of the faster cars would have more of a problem on that setup.
Old Jan 20, 2005 | 07:08 PM
kapao's Avatar
but what if you upgrade to performance pads? don't you need new rotors to compensate for the added heat that the pad will produce.
Old Jan 20, 2005 | 07:20 PM
Knestis's Avatar
Default Re: (kapao)
New rotors or different rotors? With some pads, we might change rotors as often as we do pads (new rotors), but they are all plain ol' replacement rotors.
K
Old Jan 20, 2005 | 07:25 PM
SPiFF's Avatar
Autozone here. Change them everytime I change pads. 1-2 race weekends on the GSR, depending on track.
Old Jan 20, 2005 | 07:26 PM
Willard's Avatar
not a race car...
but Autozone =
https://honda-tech.com/zerothread?id=181691
[several pix in that thread]
Old Jan 20, 2005 | 07:38 PM
Track rat's Avatar
Default Re: Rotors (SPiFF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPiFF &raquo;</TD></TR><TR><TD CLASS="quote">Autozone here. Change them everytime I change pads. 1-2 race weekends on the GSR, depending on track.</TD></TR></TABLE>
Damn Zsolt! You're blowing through pads & rotors after 1-2 weekends. Are you bending the brake pedal too?
$25 Autozone rotors for the ITR here too.
Old Jan 20, 2005 | 08:03 PM
SPiFF's Avatar
Default Re: Rotors (Track rat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">Damn Zsolt! You're blowing through pads & rotors after 1-2 weekends. Are you bending the brake pedal too? </TD></TR></TABLE>
262x21 mm rotors on a fast car. And this is with prolly ~150WHP max and 2575lbs. I don't even want to think about this year with 170WHP and 2680#
Maybe BAR will let me borrow some carbon/carbon brake parts.
Old Jan 20, 2005 | 08:20 PM
trigun7469's Avatar
Brembo
Old Jan 20, 2005 | 08:57 PM
bb6h22a's Avatar
I use the best rotors on the planet .................................................
Cross drilled, slotted with hot pink hats!!
I felt an amazing change in braking POWAH the instant I installed them (though that could have been the chili I had for lunch ... POWAH!!)
Yeah, they're totally rad man. Get um!
Actually, I use either Autozone of Cobalt blanks.
Old Jan 20, 2005 | 09:17 PM
azian21485's Avatar
sorry to highjack but since we're on the subject of brakes...i'm running generic pads from murrays (pretty much autozone)...autox i can overcome the max grip the azenis can handle under hard but modulated (not slamming on them or anything) braking...is it worth upgrading to hawks or a better compound pad? no noticable fade or anything...thoughts? i don't think i'd be able to stop any faster since i'm already overcoming the grip of the tires..but maybe i don't understand something..
Old Jan 20, 2005 | 09:20 PM
DMF's Avatar
DMF
Default Re: Rotors (azian21485)
autozone rotors here. They haven't done me wrong yet.
I go trough a set of fronts every 2-3 weekends, so the cheapest ones they have are what I buy.
Old Jan 20, 2005 | 09:22 PM
DMF's Avatar
DMF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to highjack but since we're on the subject of brakes...i'm running generic pads from murrays (pretty much autozone)...autox i can overcome the max grip the azenis can handle under hard but modulated (not slamming on them or anything) braking...is it worth upgrading to hawks or a better compound pad? no noticable fade or anything...thoughts? i don't think i'd be able to stop any faster since i'm already overcoming the grip of the tires..but maybe i don't understand something..</TD></TR></TABLE>
A higher performance pad may have better initial bite and modulation to the point of the tires weakness.
Put those pads on a road course with any adequate amounts of hard braking zones and I guarantee you will fade those pads.
Old Jan 20, 2005 | 10:28 PM
stormy's Avatar
Default Re: Rotors (DMF)
mine are forged unubtainium.
Old Jan 21, 2005 | 07:13 AM
turfer's Avatar
Default Re: (kapao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kapao &raquo;</TD></TR><TR><TD CLASS="quote">but what if you upgrade to performance pads? don't you need new rotors to compensate for the added heat that the pad will produce. </TD></TR></TABLE>
Rotors are cheap in comparison to pad sets. I can buy 8 pairs of rotors for the cost of one set of pads. We use 3 sets of pads for a season and 10-12 sets of rotors for a 10-12 weekend 15-17 race schedule.
Rick
Old Jan 21, 2005 | 07:31 AM
Chris Sawatsky's Avatar
New User
I use the cheapest rotors available, change them every 2-3 weekends I think.
My uncle owns an autozone-esque parts place, that sponsors my crx, so I think I've been paying between 10 and 15$ cdn per rotor
Old Jan 21, 2005 | 07:52 AM
naman's Avatar
well thanks for the feedback, it's good to know the 'zone will back it's lifetime warranty.
Old Jan 21, 2005 | 09:03 AM
ITC Racer's Avatar
Default Re: (naman)
I use OEM Honda on my ITC CRX and have not had any problems and sleep better knowing they are OEM. I usually get 6 plus weekends on a set with Hawk Blues.
Old Jan 21, 2005 | 12:17 PM
R you serious's Avatar
Default Re: (ITC Racer)
ive been using autozone ones for the past 2 years,, just switched to honda oem ones and they are lasting considerable longer.. go figure..
my next set will still be autozone though..
Old Jan 21, 2005 | 03:03 PM
Lo-Buck EF's Avatar
after watching willard at slummit glowing autozone rotors, a figure autozone will work fine on my slow track bucket. and as much as i crack rotors, 11.99 at autozone is the way to go. 3 month warranty+manager is the parts manager at my workplace=lots-o-free rotors
Modified by Lo-Buck EF at 7:19 PM 1/21/2005
Old Jan 21, 2005 | 04:55 PM
Hracer's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naman &raquo;</TD></TR><TR><TD CLASS="quote">What rotors do you guys use? By you guys I mean Honda Challenge, ITA, ITC, etc.
Have heard a lot of you use Autozone rotors.</TD></TR></TABLE>
Autozone rotors work fine. We started using them in '00 and have been using them since on the crx (ita/h4). We tried OEMs, brembo blanks and cryo treated brembo blanks, but we've always came back to the Autozone rotors. Just can't beat the bang for the buck. I think we've had a couple that were "bad", but it was pretty easy to notice these bad rotors from behind the wheel within a handful of laps (they warp and show cracks really fast, and you'll feel it). Even so, they are so cheap it doesn't matter. On the Integra, we had the same set of Autozone rotors since the car was built last year until the ARRC where we put on a new set of good old Autozone rotors. This first set went through four races and three test days. They do show signs of wear, but will definitely still be used again this year. So no complaints here!
93_hatchie
Suspension & Brakes
Dec 11, 2008 03:59 PM
oh-k
Aug 22, 2004 08:31 AM
Flux
May 29, 2002 07:26 PM
illusion
Apr 10, 2002 09:31 AM
