Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rattle in the steering rack
Old Feb 23, 2004 | 08:31 AM
Andy Hollis's Avatar
Default Rattle in the steering rack
89 Civic Si:
I believe I have tracked down a rattling sound when I go over small bumps to the steering rack. Its not in the suspension, I'm certain. The entire suspension has been off the car and rebuilt using new bushings. This noise existed both before and after the rebuild. It also shows itself as a clunking through the steering wheel when the car is at rest and on the ground.
I removed the boot from the right side of the steering box and the rack itself can be moved up and down noticeably. There's at least 1/16" clearance in the vertical direction. All the tie-rods ends are solid, though. The only thing I can see that could possibly cause this is wear on the internal bushing that the rack itself slides on inside the pinion housing.
Anybody else ever see this? Common issue? Should there be much play in this bushing?
Fixing it looks to be a complete remove and rebuild of the rack. Not fun.
--Andy
Old Feb 23, 2004 | 09:23 AM
j-rho's Avatar
Default Re: Rattle in the steering rack (Andy Hollis)
Andy, it's got to be those big sticky front tires causing the problem. I think if you permanently go back to some 155/70-R13 tires of at least 500 treadwear rating, on wheels no wider than 4", the problem will go away.
And certainly you don't want to go around any corners too fast now, think of that poor steering rack!
Old Feb 23, 2004 | 09:50 AM
Jon Nelson's Avatar
Default Re: Rattle in the steering rack (jzr)
There's a nylon bushing in the (passenger side) end of the rack that only costs a couple of bucks from Honda. If you've got a lot of miles on, it need replacing. Although it's not EASY, it's not impossible, and you can do it without removign the rack.
You might also check the pinion preload, it's adjustable, too.
Jon
Old Feb 23, 2004 | 10:09 AM
Default Re: Rattle in the steering rack (Jon Nelson)
Thanks, Jon. That's the one I was eyeing up as the culprit. But how do you replace it without removing the rack? Will it go over the end of the rack itself once the inner tie-rod ends are unscrewed? Or do you have to pull the rack out of the pinion housing?
TIA,
--Andy
Old Feb 23, 2004 | 10:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jzr &raquo;</TD></TR><TR><TD CLASS="quote">Andy, it's got to be those big sticky front tires causing the problem. I think if you permanently go back to some 155/70-R13 tires of at least 500 treadwear rating, on wheels no wider than 4", the problem will go away.
And certainly you don't want to go around any corners too fast now, think of that poor steering rack! </TD></TR></TABLE>
Well, your sorta right, Jason. It wasn't until I rebuilt the whole suspension, installing urethane bushings and the newly re-valved shocks that I really noticed it. Up until that point, there were other things that were worn much worse. Other than this issue, the car is so tight now that its simply amazing.
--Andy
Old Feb 23, 2004 | 11:47 AM
Tyson's Avatar
jon is correct. if youve already located it to the rack having play within the steering tube, then its that bushing. you have to remove the tie rod ball joint, which youll need a new crush washer to replace, then youll see the white plastic bushing. move the steering wheel to the right, then you can start to pick it out. you should unbolt the rack for extra room to pry it out, but no need to disconnect it from the steering column and pinion. good luck. it certainly made a huge difference for me.
Old Feb 24, 2004 | 09:55 AM
Jon Nelson's Avatar
The hardest part is getting the inner tie rod outta the rack. Crappy job.
Once you do, though, it's a snap.
Jon
Old Feb 24, 2004 | 10:06 AM
mstewar's Avatar
my old 88 integra did the same thing..
i've been told it's somewhat common on the late 80's hondas.. especially ones that have seen a bit harsher life..
Old Feb 24, 2004 | 10:57 AM
Tyson's Avatar
Default Re: (Jon Nelson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon Nelson &raquo;</TD></TR><TR><TD CLASS="quote">The hardest part is getting the inner tie rod outta the rack. Crappy job.
a slim adjustable wrench made it a snap for me.
Old Mar 2, 2004 | 08:55 AM
Default Re: (Tyson)
Final update on this one:
The new plastic bushing arrived yesterday from Majestic. About $10.
Removal of the old piece was tricky. First, remove the outer tie-rod end from the steering knuckle using any of the "usual" methods (I used pitman tool). Turn the steering wheel all the way to the left, remove rack boot from pinion housing and slide it out of the way. Use small chisel and hammer to start unbending lockwasher flaps. Use small flat round punch to finish the job. 13/16 open end wrench on the rack, and 11/16 on the inner tie rod end to unscrew it.
Now, turn the steering wheel all the way to the right (rack fully inside pinion housing). To get the old bushing out, I used a pair of very small screwdrivers to hold the retaining nubs out of their mounting holes. This also creates friction with the rack. A pair of needle-nose pliers clamped onto a piece of the bushing along with an assistant slowly turning the steering wheel to move the rack out of the housing will cause the bushing to come with it. Took me a couple of tries, but got it done.
Insertion of new bushing is simple, but be careful not to break it. And do clean/grease the rack. Reassembly is reverse of disassembly. Try and use a new lockwasher if you can (cheap from Honda).
Its also a good time to renew the tie-rod end boots. Honda sells the boots for about $2 each. You can reuse the old clips. A trick for installation to avoid the special tool is to first put the boot in place sans clip, then spiral the clip on using a very small screwdriver. I did the ball joint boots this way, too.
Botom-line: No more rattles!!! Car is tight, tight, tight!!
Hope this helps someone else.
--Andy
Old Mar 3, 2004 | 06:43 AM
crxfanatic's Avatar
New User
Default Re: (Andy Hollis)
Andy, thank you very much for the writeup! I too have an 89 Civic (over 230,xxx miles) and I need to do the bushing swap. I'm ordering parts right now...
Cheers
Old Mar 3, 2004 | 07:51 AM
91SiKen's Avatar
Default Re: (crxfanatic)
Fan, you need a partner for this? We can do both our cars.
Old Jul 27, 2004 | 10:29 AM
p1driftfiend's Avatar
Default Re: (91SiKen)
Bumping this:
Does anyone know the part number of the bushings replaced? It is the same as the steering rack bushing that comes in the ES kit?
Old Jul 27, 2004 | 11:24 AM
CRX Lee's Avatar
Default Re: (p1driftfiend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p1driftfiend &raquo;</TD></TR><TR><TD CLASS="quote"> It is the same as the steering rack bushing that comes in the ES kit?</TD></TR></TABLE>
No, the bushings in the ES kit are external bushings from the rack casing to the subframe which I have and would be hard pressed to say they did anything other than add more color under the car.
What Andy, et. al. are talking about is an internal bushing inside the rack casing. I have never changed that bushing but nor am I joyously looking forward to it on my 220K mile car.
Old Jul 27, 2004 | 12:40 PM
tom91ita's Avatar
Banned
Default Re: (CRX Lee)
its item 10 in this page correct?
http://www.hondapartssource.co...ch=no
Old Jul 27, 2004 | 12:41 PM
Tyson's Avatar
Default Re: (tom91ita)
yeah, long discussion here.
https://honda-tech.com/zerothread?id=935457
Old Jul 27, 2004 | 07:55 PM
prkiller's Avatar
Default Re: (Tyson)
I've gotta do this too!
Old Jul 28, 2004 | 06:04 AM
crxfanatic's Avatar
New User
Default Re: (prkiller)
It's been a while since I did the bushing swap. It made all the difference in teh world on my car, with 230,000+ miles. But now it seems the driver side is clunking the same way, so I assume the rack needs to be adjusted. Has anybody ordered the lock nut tool? How much is it?
hybrid90
Suspension & Brakes
Jul 30, 2019 11:47 PM
DREW410
Suspension & Brakes
Oct 19, 2017 10:06 AM
Mohsin
Oct 7, 2008 01:56 PM
RTW DC2R
Jun 22, 2003 11:02 AM
cbrf-3
Feb 5, 2002 08:44 PM
