Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
question reguarding macpherson
Old May 16, 2003 | 06:22 AM
Lo-Buck EF's Avatar
Default question reguarding macpherson
went to get rsx with flt-a2's aligned and when they took it off the ground, the front wheels had lots of right to left play(in the same movement as when the steering wheel was being turned) but individually. nothing was loose in the strut-to-knuckle area. the bottom of the shock was turning with the wheel as its supposed to, but there was play. could this be a pre-load issue (not enough)?
-spenc...confused by macfherson
Old May 16, 2003 | 06:23 AM
.RJ's Avatar
.RJ
Default Re: question reguarding macpherson (SOLOef)
what wouldnt be preloaded enough?
Old May 16, 2003 | 06:27 AM
Lo-Buck EF's Avatar
Default Re: question reguarding macpherson (.RJ)
i think the spring can be preloaded on the bottom somewhere. i talked to people when we were having other trouble with them poping and they said the pre-load was too much.
Old May 16, 2003 | 06:31 AM
.RJ's Avatar
.RJ
post it on the RSX forum here, or i'm sure there's some RSX boards
Old May 16, 2003 | 06:36 AM
Lo-Buck EF's Avatar
sounds good. thanks
Old May 16, 2003 | 07:44 AM
Todd00's Avatar
I said I don't want a title!
Make sure the top nut is tight. It's the nut that you can see from the engine bay and sits on the very top of the strut. Mine was loose on the teins and tightening this took care of the extra play.
I'm sure the JICs are similar in design.
JosephC
Dec 2, 2009 10:57 PM
blouisgod
Honda Civic (2001 - 2005)
10
Mar 22, 2009 11:04 PM
Lo-Buck EF
May 17, 2003 07:20 AM
BoxStuffer
Mar 28, 2003 02:29 PM
