Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
question about stack cluster
Old Nov 12, 2003 | 03:33 AM
euclid's Avatar
Default question about stack cluster
just curious if it will retain the turn signal lights and general check engine light. also, is there an option for lap timer?
thanks
Old Nov 12, 2003 | 03:50 AM
XrcR6's Avatar
Default Re: question about stack cluster (euclid)
You're talking about the product offerings from:
http://www.stackinc.com/ ?
No, they have no provisions for turn signal light, check engine lights, door ajar, seat belt warning, etc. as found in the OEM cluster. Some ST8xxx series do have a lap timer option however.
And they really don't retain anything for that matter, since you have install Stack sensors for all of the parameters you are tracking. You can't really reuse any of the factory sensors, they probably give out the wrong range of voltages. At least for things like temp and pressure. For speed they use a hall effect sensor.
Old Nov 12, 2003 | 03:56 AM
euclid's Avatar
Default Re: question about stack cluster (XrcR6)
yes, i am wondering about the 8100 and 8130... i see that the lap timers are an option, turn signals are no big deal, i am just concerned that if the ecu is throwing a code it will not be known.
i might opt for the st700 and mount it into my existing stock cluster.
any other recommendations are appreciated. it needs to be drivable on the street, but my car is setup for lapping and i dont want gauges all over the dash.
Old Nov 12, 2003 | 04:34 AM
rjr162's Avatar
one option is to trace and figure out what wire comming into the factory cluster triggers the check engine light, and mount a light off of that wire in another location. This way you know if that light is on, it really means "Check Engine"
Old Nov 12, 2003 | 04:50 AM
euclid's Avatar
Default Re: question about stack cluster (rjr162)
yeah, just have a seperate engine light alltogether, good idea.
it seems win/win between the tack size gauge(st700) or the full cluster(st8100).
the st700 will only allow for oil pressure and one temp readout, it has speed, acceleration timer, battery, lap timer option with memory, trip and odometer, shift lights... good for street use plus i can fit it into a civic cx cluter that only has a center mounted speedometer, plus water temp and fuel level. i could keep the stock fuel level gauge and replace the water temp sensor with an accurate aftermarket.
the full cluster will display all vital signs on the digital readout, however it will not be able to support acceleration timer, and in order to get trip/odometer and laptimer with memory i am looking at $2,000 or more. i would need to setup up a check engine light as suggested above.
basically it comes down to what i can find and afford, is anyone selling these used?
Beckerton
48
Jun 25, 2011 04:09 AM
Kid_SiR
Mar 21, 2008 10:42 PM
HondaHemi
12
Dec 21, 2005 01:17 AM
Shambo
Jul 19, 2005 12:38 PM
Baggy Spandex
10
Feb 23, 2004 05:43 PM
