Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Overheating problem
Old Sep 5, 2004 | 10:55 PM
RineRacing's Avatar
Default Overheating problem
On my 87 crx there seems to be an overheating problem. I flushed the system, and there is water flow in both radiator hoses and the radiator looks fine. What else should I be checking?
Old Sep 6, 2004 | 06:59 AM
CRX Lee's Avatar
Default Re: Overheating problem (RineRacing)
Thermostat and make sure your ignition timing is not whacked out (although I'd think that if the timing was that far off to generate extra heat, the computer would be pissed off and making the car run really badly).
Are you going to Nationals? Stop by the Koni trailer to get an adjuster **** (forgot to send one).
Old Sep 6, 2004 | 07:45 AM
gotocrx's Avatar
We had a similar problem with ours in the early days. Changing the thermostat helped alot, but it still ran hotter than we liked on summer days. A front mounted oil cooler made the problem disapear.
Old Sep 6, 2004 | 11:57 AM
RineRacing's Avatar
Default Re: Overheating problem (CRX Lee)
Looks like I'll change out the thermostat. Thanks guys.
Lee, I'm not going to nationals this year. I spent my "Nationals" fund on the CRX Just drop the adjuster in the mail when you have a chance. No rush.
Old Sep 6, 2004 | 12:01 PM
Tyson's Avatar
a weak radiator cap will not maintain the right pressure and cause overheating i believe. could be worth replacing with a new one anyway.
Old Sep 6, 2004 | 12:41 PM
johng's Avatar
Head gasket? Time for a leakdown.
Also replace the rad cap, and ECT switch (if applicable), and check the fuse that controls it. The fan might not be coming on.
See you at Infineon
Old Sep 6, 2004 | 06:31 PM
RineRacing's Avatar
Default Re: Overheating problem (johng)
I'm hoping it's not the head gasket (no oil in the water, no water in the oil) but I should to a leakdown test.
I do know the fan works but it just isn't enough in the long run.
See ya this weekend John.
Old Sep 7, 2004 | 08:46 AM
ITC Racer's Avatar
You will probably want to replace or recore the radiator. Over time, the tubes in the radiator will clog and the cooling efficiency will degrade. If replacing, put a two core unit in to give some extra capacity.
Old Sep 7, 2004 | 10:26 AM
RineRacing's Avatar
Default Re: Overheating problem (ITC Racer)
I have your suggestion of the dual core rad as a last resort on account of it being the most expensive solution. I'll change out the thermostat and test things out this weekend at Infinion. If there still is a overheating problem then I'll go pick up a dual core rad.
Old Sep 7, 2004 | 10:28 AM
tnord's Avatar
or you could just take the thermostat out if you don't have cavitation problems.
bad thermostat cost me a head
varadinn
Mar 2, 2010 02:25 PM
thakidd
May 15, 2008 01:45 PM
J1A1H
18
Jan 8, 2006 12:13 PM
tsjeff
Jun 23, 2003 08:21 PM
rb26dett
Jun 4, 2002 11:10 PM
