Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Noticeable Difference between 14s and 15s?
Old Sep 23, 2002 | 12:26 PM
mr_mbuna's Avatar
Default Noticeable Difference between 14s and 15s?
Hey guys,
I'm ordering some Falken Azenis soon, and I'm wondering whether to put them on my 14" steelies, or on my 15" LS mesh daily driven rims? Is there going to be a noticeable difference during an autocross with 14s vs 15s, or should I put the Azenis on my daily driven 15s and use those 15s at the track and just forget about the 14s?
Thanks,
Ben
Old Sep 23, 2002 | 12:40 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Noticeable Difference between 14s and 15s? (mr_mbuna)
I personally wouldn't want to use steelies for autox or track use. Put the tires on the 15's. You get more contact patch that way too.
Old Sep 23, 2002 | 01:03 PM
RineRacing's Avatar
The 14s will give you a better gear ratio for autocross and the 15s will work better for the track.
Old Sep 23, 2002 | 01:25 PM
Mojo-Jojo's Avatar
Default Re: Noticeable Difference between 14s and 15s? (Geratol)
Uhh...not if the circumference of the tire doesn't change. If he's planning on getting low profile tires on the 14's, then yeah, it would be shorter all the way around than stock, and would be better. Otherwise, it's the same.
I'd put it on the 15's and throw away the 14" steelies, unless you need them for some snow tires.
Old Sep 23, 2002 | 02:07 PM
Geezer's Avatar
The other variable is wheel width. I've had 205/40/15 Azenis on both 15x6 and 15x7 wheels, and the extra inch made an appreciable difference.
Old Sep 23, 2002 | 02:59 PM
RineRacing's Avatar
Default Re: Noticeable Difference between 14s and 15s? (Mojo-Jojo)
Uhh...not if the circumference of the tire doesn't change.[/QUOTE]
Well Duh.
Old Sep 23, 2002 | 03:24 PM
smokin rubber's Avatar
I had the 14 azenis and definatly wanted a little more tire under the car, so instead of buying some 15s I got sticky r compounds instead. I would reccomend the 15in azenis unless you are on a budget.
Old Sep 23, 2002 | 04:21 PM
mr_mbuna's Avatar
Default Re: Noticeable Difference between 14s and 15s? (smokin rubber)
Should I buy Azenis now, or should I wait till spring? Is there any reason not to buy new tires at the beginning of winter/end of fall? We don't really get that much snowfall.
Ben
ludeDVR
12
Dec 19, 2008 06:33 AM
GettaluvR
Aug 21, 2003 09:15 AM
mr_mbuna
Sep 26, 2002 01:58 AM
Petah
Oct 17, 2001 09:44 AM
onyx00
Sep 25, 2001 02:15 PM
