Nasa Class difference
Nasa racers, I have question on car difference between H1 and GTS3.
How much difference between the top ranked drivers of H1 vs GTS3 class?
Since most GTS3 class racers use mostly stock m3 motor, and H1 class uses hybrid setup, the cost to run in H1 is a bit higher than GTS3 right?
Not sure how many Honda guys are going to be familiar with the GTS3 rules. The Porsche/BMW types usually pit as far from us as they can...
The lap-time comparisons from the NASA nationals in both classes might be more helpful than we are.
To tell you the truth, I don't think the costs would be that much different between the two classes.
The repair costs on an H1 car are SOOO much cheaper than the GTS3 car depending on what you choose to race.
Consumables will be cheaper on the H1 car though.
Motor wise, I bet engines would be roughly the same price to replace if not giving the edge to the H1 engine being cheaper.
Racing at any top level is gonna be expensive though and you can spend as much money as you want on anything you want.
It looks like laptimes are fairly similar, given the highest levels of preparation as a comparison. Within a few tenths, with H1 cars looking to get the nod at some tracks, GTS3 at others. Kinda surprises me, as I thought the GT cars were significantly faster.
VIR Full:
H1 - 2:11.5 (been lowered, but not officially I think)
GTS3 - 2:09.2
VIR North:
H1 - 1:40.1
GTS3 - 1:40.5
Summit Point Main:
H1 - 1:21.9
GTS3 - 1:21.5
CMP:
H1 - 1:46.1
GTS3 - 1:46.3
VIR Full:
GTS3 - 2:09.2
VIR North:
H1 - 1:40.1
GTS3 - 1:40.5
Summit Point Main:
H1 - 1:21.9
GTS3 - 1:21.5
CMP:
H1 - 1:46.1
GTS3 - 1:46.3
Thanks everyone for these good info.
Would you guys build a car to race in a class where your friends are? Or the fun factor doesn't change even just going racing yourself?
You should race where there is competition, whether it's with your friends or not. If you're racing as the only guy in your class, that would probably feel pretty lame.
Build an H2 car!
That is the class between the two you are talking about that you want to build for.
The overall build will be much cheaper and the cost difference between and H2 can and a GTS 3 car won't even compare. You'll be way ahead of the game with the H2 car and the is competition is growing around the country in that class.
Build an H2 car!
The gsr will make a great H2 car, the motor is required to be internally stock but is allowed a blox or skunk intake manifold along with a 62mmTB, they make good power and are capable of running up front at nationals.
But yes, race and build a car for where there is competition. GTS2 and GTS3 are pretty big in MidAtlantic right now, H1 and H2, not as much.
Im obviously biased, but we get to win Hoosiers also
Then again, if you arent winning tires, Toyos are a little cheaper than the Purple Kool Aid. Regardless, racers in both classes are awesome to hang out with. Contrary to what Thawley says, Im always hanging around the HC paddock
so no cams, cam gears then ?? what about trans setup?? can the head be milled, or 2 layer HG?? thanks
You can raise the compression to 11.1-1, either from a head or block shave, or with the gasket
Jason Miller
Oct 29, 2008 10:31 AM
crx12
Dec 11, 2002 11:24 PM
