Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Minimum weights!
Old Dec 11, 2002 | 10:05 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Minimum weights!
The minimum weights are posted for ECHC! They include the driver! I can get off my diet!
Ah, next year looks like it might be fun.
--chris, who is still going to have to ballast his car to meet 2000 pounds.
Old Dec 11, 2002 | 10:10 AM
EFFECT's Avatar
Default Re: Minimum weights! (madhatter)
Speaking of ballasts, where would you get them made for you? (looks like I will need some too)
Old Dec 11, 2002 | 10:15 AM
Crack Monkey's Avatar
Default Re: Minimum weights! (EFFECT)
Most people use weights from a weight set for ballast.
Also, not sure if NASA has this rule, but SCCA IT requires ballast in 25lb increments and max of 100lbs. Those of you with dual use car need to check the GCR.
Old Dec 11, 2002 | 11:00 AM
Tyson's Avatar
Default Re: Minimum weights! (Crack Monkey)
http://www.maycoindustries.com/indus...ead_bricks.htm
Old Dec 11, 2002 | 03:58 PM
madhatter's Avatar
Default Re: Minimum weights! (Tyson)
Lead shot, available at your nearest temple-unto-death-of-all-things-furry (AKA Bass Pro Shop) comes in 25 lb increments.
Old Dec 11, 2002 | 04:34 PM
Knestis's Avatar
I understand that Winston Cup teams (and other big-buck outfits) use tungsten for ballast blocks - 1.7x the density of lead. Shot isn't legal in most racing organizations although I have, uh, heard of some guys putting shot in cage tubes before welding them up. A circle track guy in Washington State filled the box member lower rails of his chassis with mercury one time, too. He had a big wreck, cracked the frame, and was found out when it started to leak onto the track. The idea was that it would shift mass onto the rear tires under acceleration and onto the fronts under braking but, talk about your Superfund clean-up issues!
Kirk
Old Dec 11, 2002 | 04:46 PM
solo-x's Avatar
Default Re: Minimum weights! (Knestis)
Kirk
geez! that's a crapload of mercury to feel any effect.
nate
Old Dec 12, 2002 | 12:06 PM
smokin rubber's Avatar
Default Re: Minimum weights! (urbanlegend21)
quick morgan delete your post.
Old Dec 12, 2002 | 12:08 PM
Mike_C's Avatar
Default Re: Minimum weights! (smokin rubber)
When will weights be taken? Before or after the race?
Old Dec 12, 2002 | 12:09 PM
Default Re: Minimum weights! (JMU1337)
IT weights are taken after the race, I would assume HC will be the same.
Old Dec 12, 2002 | 12:12 PM
travis's Avatar
Yes, fuel cannot help you make minimum weight. However, mud and dirt do.
Old Dec 12, 2002 | 12:13 PM
After, otherwise everybody would be leaving bumpers, glass, and misc bodywork all over the place on the warmup lap.
Old Dec 12, 2002 | 12:15 PM
So even if there was an incident, and your bumper was bumped off, the car would still be illegal?
Old Dec 12, 2002 | 01:27 PM
Knestis's Avatar
I believe that IS the case in SCCA... Same theory is applied to sound control, following an alleged "quick release muffler" incident back in the '80s.
Kirk
portenio78
Feb 11, 2010 06:41 AM
ITR1148
Sep 19, 2007 08:16 AM
4crx4me
May 18, 2004 09:03 PM
MaddMatt
18
Sep 16, 2002 06:20 AM
redteg1
Mar 4, 2002 05:25 PM
