Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
lug nut tech....need help
Old Jul 14, 2003 | 03:52 PM
CLICC916's Avatar
Default lug nut tech....need help
hey i figured the road racing guys should know this...i wanna know if lugnuts can change the way your car handles, specifically at higher 60mph+ speeds...ok here's some background info:
previous setup:
les schwab "performance" 195/50/15 tires (forgot which brand, but its not a big name) in front, very used-up dunlop 195/50/15 fm901's in the rear, and flat-faced lugnuts.
i wore down the rear tires away from home, so i had to purchase new les schwab ones, the same exact brand and size of that on the front. while my tires were being put on, one of the guys working there came in and told me that i didn't have stock honda lugnuts because they were flat on the end facing the inside of the car. since some of them were rusted, i decided to buy a new set of lugnuts, the 'stock' ones. he told me that the 'stock' lugnuts were tapered to "secure the wheel to the car". anyway, long story short, after i got those lugnuts and swapped the back tires, my car handles a little softer than before with more noticable body roll...
my question is, does the lugnuts have anything to do my handling?
Old Jul 14, 2003 | 04:03 PM
.RJ's Avatar
.RJ
Default Re: lug nut tech....need help (CLICC916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLICC916 &raquo;</TD></TR><TR><TD CLASS="quote">my question is, does the lugnuts have anything to do my handling?</TD></TR></TABLE>
Nope. And FWIW, OE honda lugs are acorn-style not tapered.
Old Jul 14, 2003 | 04:06 PM
mph6563's Avatar
Default Re: lug nut tech....need help (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Nope. </TD></TR></TABLE>
Well, they can, but you usually hear a loud scraping noise as the car pulls to one side. You may also see courseworkers running away from the wheel that's flying toward them.
Old Jul 14, 2003 | 07:28 PM
philstireservice's Avatar
actually RJ, Honda and Acura lug nuts have a ball seat. So do most VW's and Audi's. Most other lug nuts have a conical seat............just to get technical..
Old Jul 14, 2003 | 07:46 PM
Mohudsolo's Avatar
Default Re: lug nut tech....need help (Maxx44)
"Honda and Acura lug nuts have a ball seat."
What he said. Use factory nuts with factory wheels and aftermarket with aftermarket. If you have aftermarket wheels, keep a set of factory nuts to use with the spare.
Old Jul 15, 2003 | 05:18 AM
Floyd's Avatar
Default Re: lug nut tech....need help (Mohudsolo)
I think you guys are saying the same thing. Ball-seat... Acorn-seat. They both have a spherical contact area where aftermarket wheels require a conical seat.
As far as the handling, sounds like the new tires might need to be broken in. As far as body roll goes, there should be any difference when changing tires. Must be a perception thing.
Old Jul 15, 2003 | 05:39 PM
CLICC916's Avatar
Default Re: lug nut tech....need help (Floyd)
thanks guys, i thought the change in handling was due to my tires too but i wasn't sure. i got the conical type for my rota's...
jkd_eg8
Mar 20, 2011 07:07 PM
Backk InTheDA
Northwest (Sales)
Feb 8, 2010 02:56 PM
pvt_awol
Mar 7, 2008 10:06 AM
CLICC916
Jul 16, 2003 07:45 AM
