Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Koni Help!
Old Apr 9, 2007 | 05:01 AM
b16a1eg6's Avatar
Default Koni Help!
i have a 1991 Civic STD. This past weekend i did an engine swap and installed some Koni SPSS w/ Ground control springs. The problem i am having is that the axles are clicking when you turn the wheel hard. I raised it up as far i could and it still did it. After that i installed the stock shocks with the GC's and i goes fine. Is it too much of an angle for the axles or lowered too much? What can I do to fix it?
Old Apr 9, 2007 | 05:12 AM
MoonScryer's Avatar
Default Re: Koni Help! (b16a1eg6)
What swap? What axles?
Old Apr 9, 2007 | 05:50 AM
MoonScryer's Avatar
Double post.
Old Apr 9, 2007 | 06:25 AM
johnny6speed's Avatar
Default Re: Koni Help! (MoonScryer)
Bump for quick solution!
Old Apr 9, 2007 | 06:41 AM
b16a1eg6's Avatar
Default Re: Koni Help! (johnny6speed)
B16A1, hasport mounts, Raxles
Old Apr 9, 2007 | 09:14 AM
b16a1eg6's Avatar
I know I made a few of these post but I really need help with this.
Old Apr 9, 2007 | 09:55 AM
tronic's Avatar
clicking axles usually means a bad outer CV joint.
if you swapped in different shocks, and the ride height is the same, why would different shocks matter?
Old Apr 9, 2007 | 01:44 PM
b16a1eg6's Avatar
Default Re: Koni Help! (tronic)
No the ride height is not the same its higher with the Koni's. SPSS Koni's are shortented vs just having coilovers in with the stock shocks. I was just wondering how low is too low for the axles or if anyone had this same problem.
Old Apr 9, 2007 | 02:37 PM
BrianZ's Avatar
do you have an LSD in this car? I have heard some clutch lsd's make clicking sounds when turning..
Old Apr 10, 2007 | 04:20 AM
b16a1eg6's Avatar
Default Re: Koni Help! (BrianZ)
No unfortunately no diff. I think it has to do with ride height.
Old Apr 10, 2007 | 06:33 AM
HondaF1Fanatic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tronic &raquo;</TD></TR><TR><TD CLASS="quote">clicking axles usually means a bad outer CV joint.
if you swapped in different shocks, and the ride height is the same, why would different shocks matter?</TD></TR></TABLE>
x2
Jon
Old Apr 10, 2007 | 04:26 PM
CRX Lee's Avatar
Default Re: Koni Help! (HondaF1Fanatic)
I can't see how the Konis can be having this effect. You must have changed something even in the basic instaltion process that you didn't pick up on. Axle clicks are a rotational thing and whatever shocks you have don't have any effect on something rotational. I have never done a B16A installation but I have also never had any axle clicks other than a bad CV joint regardless of ride height.
Old Apr 10, 2007 | 08:48 PM
Colin's Avatar
Default Re: Koni Help! (CRX Lee)
Are the raxles new or used?
I've had raxles on my DA for something like 6-8yrs now and generally I have been very satisfied with them. However I had to replace them twice. First time was after about 4yrs of use, the boots wore out. No clicking, just worn boots from the car being lowered quite a bit. Raxles replaced these free of charge.
Soon after my first axle replacement the clicking started. I think I just got a bad set. Again, they replaced them for free.
If I were you I'd get in touch with raxles.
Old Apr 12, 2007 | 07:15 AM
b16a1eg6's Avatar
Default Re: Koni Help! (Colin)
I talked to Chris at Red Shift and he suggested I make a new upper mount. Basically the opposite of the extended top mount. So I can gain some ride height back.
Old Apr 12, 2007 | 07:26 AM
Bakeoff's Avatar
no offense, but the suspension is not your issue. How many cars have been lowered with how many setups without causing issues?
I have a better question for you... Why not use the 2G teg axles? Way cheaper, and that will help identify the issue. Even grab a set from a junkyard to test it. But I would put money on it not being your suspension causing the axles to click. Lots and lots or American dollars.
b16a1eg6
Suspension & Brakes
Apr 9, 2007 06:25 AM
b16a1eg6
Apr 9, 2007 06:24 AM
JDM_Ej
Suspension & Brakes
Dec 13, 2005 03:52 PM
JDM_Ej
13
Dec 12, 2005 01:54 PM
civicmon
Sep 21, 2004 05:00 PM
