Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How to wire seperate check engine light?
Old Jun 8, 2007 | 07:15 PM
ekim952522000's Avatar
Default How to wire seperate check engine light?
Hey guys I finally got my gauges in a want to elimanate the stock gauge cluster does any one know how I could wire a new check engine light and get rid of the one in the cluster?
is it as simple as looking at the wiring diagram in the owners manual and just splice in a new one?
Old Jun 9, 2007 | 09:23 AM
Justin3's Avatar
Default Re: How to wire seperate check engine light? (ekim952522000)
It's that easy, just look at your wiring diagram. Run a wire from your ECU's MIL wire to your bulb of choice and a power source and you should be good to go.
Old Jun 9, 2007 | 11:07 AM
Default Re: How to wire seperate check engine light? (Justin3)
Thanks!
Old Jun 11, 2007 | 10:13 AM
nonsense's Avatar
While you're at it you can also wire a switch to the jumper plug so you can check engine codes and set timing without ever having to use a jumper wire.
Old Jun 11, 2007 | 11:48 AM
Default Re: How to wire seperate check engine light? (nonsense)
Great idea thanks
breadman
Honda Fit
Mar 19, 2011 09:24 PM
dohc_profile
Apr 21, 2006 09:17 PM
95LSDOHC
May 5, 2004 09:43 PM
everafter
Jan 4, 2004 07:23 PM
