Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How do you stop the back from becoming dynamically too light?
Old Jun 17, 2006 | 07:22 PM
b*saint's Avatar
Default How do you stop the back from becoming dynamically too light?
Alright as I watch more car racing videos (on the track not street) I notice a lot of CTRs or ITRs where they brake hard and even without braking too hard the back tires will break free on a curve. I'd imagine the springs aren't stiff enough up front or the travel is too long right?
Old Jun 17, 2006 | 08:05 PM
Chris F's Avatar
Default Re: How do you stop the back from becoming dynamically too light? (b*saint)
Weight shift is only determined by the center of gravity location and wheelbase.
So, the cars you're seeing have one of a few problems--
- The brake bias is wrong
- The driver is braking too far into the corner
- The rear is lifting too high (too soft spring) and the rear wheels are toe-ing out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b*saint &raquo;</TD></TR><TR><TD CLASS="quote">the back tires will break free on a curve.</TD></TR></TABLE>
You'll also see the tires come up into the air on the inside, that's not a real problem on a FF car.
Old Jun 17, 2006 | 10:02 PM
FlyZlow's Avatar
Default Re: How do you stop the back from becoming dynamically too light? (Chris F)
Re: how to keep the rear from getting too light
There are a number of factors (suspension geometry, spring rate, swaybar effect, etc) that determine the point at which the car will begin to rotate in a turn, but the short answer to your question is just to not brake as hard while turning. For any given setup, you need to know where that limit is and not exceed it by trail braking too hard or too deap into the corner. The harder you press the brake, the more weight that transfers to the front tires and off of the rears. The less weight on the rear tires, the less traction they have to hold the corner.
Old Jun 18, 2006 | 09:47 AM
b*saint's Avatar
Default Re: How do you stop the back from becoming dynamically too light? (FlyZlow)
This is where a real rear spoiler would come into play on a fwd car right? Alright so since my Prelude is 67/33 or something close to that, how would I keep the weight shifting too far forward and still be able to brake really late? Stiff springs up front right? Adjusting brake bias will work also? The do sell a adjuster to retrofit to a system...
Old Jun 18, 2006 | 10:48 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b*saint &raquo;</TD></TR><TR><TD CLASS="quote">This is where a real rear spoiler would come into play on a fwd car right? Alright so since my Prelude is 67/33 or something close to that, how would I keep the weight shifting too far forward and still be able to brake really late? Stiff springs up front right? Adjusting brake bias will work also? The do sell a adjuster to retrofit to a system...</TD></TR></TABLE>
The OEM system's brake bias is sufficiently far forward. You can also use the difference in coefficient of friction in front/rear brake pads to "adjust" the brake bias, lots of people do this on race cars).
Don't bother doing anything until you have a real problem, not an "on paper" problem.
p.s. find RR98ITR's signature. It's that simple.
Old Jun 18, 2006 | 11:03 AM
Kouki-EK9's Avatar
Does brake bias really haven any effect on weight transfer while decelerating? I just don't see it.
Old Jun 18, 2006 | 11:09 AM
FlyZlow's Avatar
An effective spoiler will help keep weight on the rear wheels in a high speed turn. I wouldn't mess with the brake bias based on trailbraking because you'll still do 80+% of your braking in a straight line, so it's much more important to have a good setup for that. If you don't have much/any track experience, you should be doing 100% of your braking in a straight line. Stiffer springs up front will keep more weight on the rear, however, you typically sacrifice turn in by not having as much weight/traction on the fronts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Word.
Old Jun 18, 2006 | 12:43 PM
BrianZ's Avatar
I would not worrier about the weight difference. my car has a split similar to yours, and I can brake plenty late
Old Jun 18, 2006 | 03:02 PM
b*saint's Avatar
Default Re: How do you stop the back from becoming dynamically too light? (BrianZ)
So bascially I cant drive it like my BMW.
Old Jun 18, 2006 | 03:23 PM
DonF's Avatar
Not unless it is a BMW MINI.
Old Jun 18, 2006 | 04:39 PM
b*saint's Avatar
Default Re: How do you stop the back from becoming dynamically too light? (DonF)
haha no way. i drive a real bmw.
Old Jun 19, 2006 | 06:43 AM
emwavey's Avatar
Brake straighter.
Understeer
Suspension & Brakes
May 21, 2006 10:41 PM
miksew
17
Oct 29, 2003 04:42 PM
jonnybravo
30
Oct 13, 2003 07:30 PM
strungoutlude
Aug 5, 2003 01:25 PM
Veritas-Aequitas
Dec 13, 2001 06:55 PM
