Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How do you attach a racing harness?
Old Mar 23, 2004 | 09:41 PM
Smeeg Heed's Avatar
Default nevermind
I'm an idiot. I forgot to search. SORRY.
Just for the record. I'm not doing thi for looks, I wanted to be more securely mounted in my seat.
Modified by NS98GSR at 7:16 AM 3/24/2004
Old Mar 24, 2004 | 02:29 AM
jc836's Avatar
Default Re: nevermind (NS98GSR)
Go directly to either the Simpson or NASA websites. You will find the drawings that you need on them. The install is very simple if you take your time. If you are using a 5-point harness the easiest install for the lapbelts will be to forged eye-bolts on the floor. DO not skimp on the giant washers (1 on each side please). The shoulder harness is available in several setups, but for track it is best to have a rollbar with a horizontal tube to wrap the harness around. Otherwise use a location that is not too far from the seatback and at the correct angle. A warning about real harnesses-you should not use them in a car where the seat is of the 2-piece variety.
Old Mar 24, 2004 | 07:45 AM
bad-monkey's Avatar
Default Re: nevermind (jc836)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 &raquo;</TD></TR><TR><TD CLASS="quote">Go directly to either the Simpson or NASA websites. You will find the drawings that you need on them. The install is very simple if you take your time. If you are using a 5-point harness the easiest install for the lapbelts will be to forged eye-bolts on the floor. DO not skimp on the giant washers (1 on each side please). The shoulder harness is available in several setups, but for track it is best to have a rollbar with a horizontal tube to wrap the harness around. Otherwise use a location that is not too far from the seatback and at the correct angle. A warning about real harnesses-you should not use them in a car where the seat is of the 2-piece variety.</TD></TR></TABLE>
for a car with no cage, the most common mounting position for the shoulder belts is the rear driver's side backseatbelt shoulder belt bolt.
another note of caution: do not use harnesses while daily driving b/c if you roll your car, it's broken vertebrae time. well ideally you wouldn't use them without a roll cage ever, (and helmet) but i'm not really one to say that as i use em during auto-x's to hold me in better too.
what's everyone's thoughts about that in general?
Old Mar 24, 2004 | 07:53 AM
Crack Monkey's Avatar
Default Re: nevermind (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">what's everyone's thoughts about that in general?</TD></TR></TABLE>
That harnesses without rollover protection are far from ideal, but for many it is a tolerable risk in autocross situations.
Autocrossing is the only situation where I would use a harness without a rollbar/cage. On the track, without rollover, I'll use the OEM belt. On the street, it is always OEM belts for me.
Old Mar 24, 2004 | 02:36 PM
Jer's Avatar
Jer
Default Re: nevermind (Crack Monkey)
i dont see a problem using a harness for any type of driving if you have a roll bar. i daily drive with 5pt harnesses and a roll bar in my car.
EusebioSam19
Aug 20, 2009 02:01 PM
jcsurfer8386EF
Oct 21, 2006 08:27 AM
HondaMang
Nov 11, 2004 02:00 PM
teggytegteg
May 13, 2004 02:27 AM
