Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Help with SCCA Classing?
Old Mar 7, 2009 | 08:06 PM
Megalomaniac's Avatar
Default Help with SCCA Classing?
A little confused as to what class my car would be put in H Stock or STS2? I have a 93 Del Sol Si, with the following mods Poly Urethane Motor Mounts, Front Upper Strut Tower Bar, Rear Upper Strut Tower Bar, Front Lower Tie Bar, and Rear Lower Tie Bar. Does having those put me out of the regular stock classes?
Old Mar 7, 2009 | 08:37 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Help with SCCA Classing?
I am 99% sure that will put you out of stock class. I think the motor mounts would do it "the most" and would also be the biggest PITA to change. The other things you could just unbolt.
Old Mar 7, 2009 | 09:37 PM
Egezzy's Avatar
Spongebrad Squarepants
you said what i was thinking.
Old Mar 9, 2009 | 04:15 PM
The other thing I meant to ask was, I switched from a blown out D16z6(USDM) to a D15B(JDM) will that motor swap also put me out of a stock class?
Old Mar 9, 2009 | 05:17 PM
Suspetise...
Yep. That will probably put you in SM or a Prepared class in fact, so the other things don't matter. That's a WAY bigger deal than the motor mounts and stuff, even if the power difference is negligible.
Old Mar 9, 2009 | 07:23 PM
ScottBell's Avatar
If you are new to auto-x, just enter as a G stock car, where B-series powered Del Sol would be classed. Unbolt the stuff that can be unbolted. Be up front with anyone that asks what is in your car.
If you really get into the auto-x stuff, you will be better off selling the car and getting something that will be completely legal. Engine swaps will put you into the Modified classes where newcomers do not belong.
Old Mar 10, 2009 | 06:29 AM
mustclime's Avatar
in case you do not have a rule book.....here you go...
http://scca.com/documents/Solo_Rules...Solo_Rules.pdf
Its that hard to read once you get a feel for how its set up.
Old Mar 10, 2009 | 03:21 PM
-Scott, I've Autocross'd before just not with the SCCA. My local club (NYBMWCCA) doesn't use SCCA classing they only go by # of Cylinders (4, 6, 8) with FI bumping you up a class and separate classes for non-DOT Tires.
-mustclime, I read the rules and was more confused as to where my car stood between Stock and STS2.
-Everyone, Thanks.
Old Mar 10, 2009 | 03:50 PM
Suspetise...
This is the single most important thing for deciphering SCCA nonsense: "if it doesn't say you can, then you can't."
Old Mar 10, 2009 | 03:54 PM
rockdude14's Avatar
-Everyone, Thanks.
You dont have the stock engine
your not even close to stock
youd be in street mod
racekar711
Suspension & Brakes
Nov 30, 2005 12:57 PM
DOHCsideracing
Jan 20, 2005 05:09 AM
CaptinMcnut
Nov 11, 2004 12:40 PM
VTEConly
May 23, 2004 07:24 PM
93EH6
Dec 27, 2002 09:09 PM
