Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
help choosing spring dimensions
Old Sep 19, 2004 | 02:03 PM
azian21485's Avatar
Default help choosing spring dimensions
Hi i need help choosing my spring dimensions because i'm not familiar with custom springs...i'm planning on using my brother's old threaded perches from his old coilovers with koni yellows
my question is how do i determine the diameter of the springs i need?
should i just measure the inner diameter of the springs or the perch that are already on there?
are any diameters interchangeable? like will a 2.5 diamter spring work as well as a 2.25?
how important is the spring length? i know they'll have to be long enough to fit the perch but what's the difference between getting a long spring and a short spring since they don't affect ride height cus i'll be able to adjust the height
Old Sep 19, 2004 | 06:46 PM
travis's Avatar
Default Re: help choosing spring dimensions (azian21485)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">Hi i need help choosing my spring dimensions because i'm not familiar with custom springs...i'm planning on using my brother's old threaded perches from his old coilovers with koni yellows
how important is the spring length? i know they'll have to be long enough to fit the perch but what's the difference between getting a long spring and a short spring since they don't affect ride height cus i'll be able to adjust the height </TD></TR></TABLE>
Do you know that the "old threaded perches" fit the Konis? That's the first thing to check. Next, you can measure the diameter of the threaded ring on which the springs sit. There may be dampers that can use either a 2.25 or a 2.5, but generally I think it's one or the other. Measure the perch ring to be sure. Best case, take them to a local shop and test fit springs.
As for the length, that will depend on the ride height and the height of the perches. You are correct that the height doesn't matter too much as the perches are adjustable, but you want a length that gets the adjustable perch somewhere away from the extremes (all the way up or all the way down). Most Hondas end up between 6" and 8" and will depend on the desired ride height and the spring rate.
Old Sep 19, 2004 | 08:51 PM
azian21485's Avatar
Default Re: help choosing spring dimensions (travis)
cool thanks..[QUOTE=travis]
Do you know that the "old threaded perches" fit the Konis? That's the first thing to check. QUOTE]
yea i just realized that midway through the day that i didn't know if they fit or not..is there any way i can tell by the dimensions or do i have to call up koni?
Old Sep 19, 2004 | 10:13 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">is there any way i can tell by the dimensions or do i have to call up koni?</TD></TR></TABLE>
I can't help you there. I have only used Konis with GC sleeves designed to fit the Konis and I don't have experience with other applications.
Old Sep 20, 2004 | 09:17 AM
azian21485's Avatar
is it ok to use different brand springs in the front and rear? for example, using a skunk2 coilover sleeves in the rear with eibach ers in the front using the skunk 2 threaded perch?
Emerica
Suspension & Brakes
Oct 11, 2007 10:52 AM
Blizzard
Suspension & Brakes
Jul 7, 2006 06:25 PM
bosco500
Jun 8, 2005 05:32 AM
bosco500
Suspension & Brakes
Jun 7, 2005 08:28 AM
Sportmode
Apr 25, 2003 11:10 PM
