Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
harness question
Old Jun 16, 2003 | 10:28 AM
keithv's Avatar
Default harness question
this might be a stupid question, but i gotta ask.
is there any other way of mounting the shoulder straps to the harness bar portion of the cage than what is shown below?
i think this is a johng picture. i hope he doesn't mind me using it. if the owner of this pic doesn't want it used, please IM me and i will delete it from this thread.
i thought i had seen the straps mounted so the excess strap was facing "down". as seen above, the excess faces toward the back of the seat.
i guess i am just picky and don't like the excess flopping around like that.
thanks.
Old Jun 16, 2003 | 11:04 AM
.RJ's Avatar
.RJ
Default Re: harness question (keithv)
Actually this is incorrect (per Simpson's instructions), as you should l00p them back through the backside metal tab one extra time.
Old Jun 16, 2003 | 11:06 AM
SJR's Avatar
SJR
Default Re: harness question (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Actually this is incorrect (per Simpson's instructions), as you should l00p them back through the backside metal tab one extra time.</TD></TR></TABLE>
per everybody's instructions, really. Anybody here rock climb? you should ALWAYS double back on the buckles.
Old Jun 16, 2003 | 11:22 AM
keithv's Avatar
Default Re: harness question (SJR)
thanks for the info guys. i found this while surfing simpson's site...
http://www.simpsonraceproducts....html
Old Jun 16, 2003 | 11:23 AM
StageOne's Avatar
On a related side note, the latest issue of SportsCar has an article dealing with safety devices and the correct way (and incorrect way) to mount harnesses. May want to check it out.
Old Jun 17, 2003 | 07:00 AM
mityVR6's Avatar
Default Re: harness question (StageOne)
Isn't that shoulder harness coming down at a rather steep angle? Should that harness bar be placed a bit higher inside the main hoop of the cage?
-Adam
.RJ's Avatar
.RJ
Default Re: harness question (mityVR6)
The angle is fine...
Old Jun 17, 2003 | 07:06 AM
siisgood00's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJR &raquo;</TD></TR><TR><TD CLASS="quote">
Anybody here rock climb? you should ALWAYS double back on the buckles.</TD></TR></TABLE>
Old Jun 17, 2003 | 07:42 AM
keithv's Avatar
Default Re: harness question (siisgood00)
on a smiliar note, has anyone ever used the sparco bolt-in kit with the lap belt? the lap belt is wider than the slot in the bolt-in kit. how do i attach the belt to the bolt-in kit?
Old Jun 17, 2003 | 09:46 AM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">on a smiliar note, has anyone ever used the sparco bolt-in kit with the lap belt? the lap belt is wider than the slot in the bolt-in kit. how do i attach the belt to the bolt-in kit?
Not just limited to Sparco, common any time a 3 inch belt is used in a 2 inch mount. If you have no access to a 3 inch slotted kit, fold the outer 1/2 inch from each side back under and insert it. If you fold under it can look pretty tidy but you are functionally doubling the thickness going through the slot. Doing this to make a single pass through is not a big deal but you still need the 3 inch sliding buckles to make your multiple passes through to lock the belt back to itself.
Old Jun 17, 2003 | 09:54 AM
Watkinsm3's Avatar
Default Re: harness question (CRX Lee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee &raquo;</TD></TR><TR><TD CLASS="quote">
Not just limited to Sparco, common any time a 3 inch belt is used in a 2 inch mount. If you have no access to a 3 inch slotted kit, fold the outer 1/2 inch from each side back under and insert it. If you fold under it can look pretty tidy but you are functionally doubling the thickness going through the slot. Doing this to make a single pass through is not a big deal but you still need the 3 inch sliding buckles to make your multiple passes through to lock the belt back to itself.</TD></TR></TABLE>
They show this in the simpson install diagram someone posted earlier in this thread.
Old Jun 18, 2003 | 04:34 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: harness question (Watkinsm3)
wowee, i never knew about step 4....
beoy9
Jul 16, 2007 07:02 AM
suprmods
Jan 10, 2006 07:19 PM
AWD: Jeff
Honda S2000
Jun 29, 2004 08:38 PM
tbcmorris
Mar 17, 2004 06:59 AM
Buttcrack
Mar 6, 2003 12:28 PM
