Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
half shaft install tips?
Old Aug 19, 2002 | 10:26 PM
Lo-Buck EF's Avatar
Default half shaft install tricks?
i'm having unusual difficulty gettin my new half shaft to seat in the trannie. i checked to see if it was the correct one and it is and everything checks out. i know u have to just force it till it goes, but an hour later its not in and i'm wondering if anyone has any tips/tricks to gettin this thing in. i had to do the other side earlier in the year and it only took 20 min. what gives?
-spencer......almost desided to sleep in the driveway till the sprinkler came on
[Modified by SOLOef, 2:29 AM 8/20/2002]
Old Aug 19, 2002 | 10:38 PM
civicrr's Avatar
Default Re: half shaft install tricks? (SOLOef)
Last time I did axles, I supported the hubs with jackstands to get the axles straight in line with the tranny. They slide right in. I didn't do it that before & it took an eternity.
Old Aug 19, 2002 | 11:03 PM
Lo-Buck EF's Avatar
Default Re: half shaft install tricks? (civicrr)
aaahhhhhh. thanx for the tip. i will try that in the morning
-spenc
Old Aug 19, 2002 | 11:38 PM
Kamin's Avatar
its just the half shaft correct? not the axle connected to the half shaft?
it should slide right in, try to center the set ring and just push.
[Modified by KAMiN, 12:40 AM 8/20/2002]
Old Aug 20, 2002 | 06:01 AM
Lo-Buck EF's Avatar
Default Re: half shaft install tricks? (KAMiN)
its the whole thing, half shaft with cv's and new boots.
-spenc
Old Aug 20, 2002 | 07:31 AM
keithv's Avatar
i know that people say not to hammer on an axle, but when i did mine it wouldn't go in a well. i think the snap ring at the end was a little too big, but we couldn't crimp it more. what i did was this:
1. compressed both CV joints so there was no slack.
2. took a dead blow hammer and gave the axle a few good whacks.
2-3 whacks with the dead blow hammer got the axle to seat in nicely. i haven't had a problem with the axle yet and its been like 4 months.
Old Aug 20, 2002 | 08:03 AM
Knestis's Avatar
Default Re: half shaft install tricks? (breaka_1_9)
Kirk
Old Aug 20, 2002 | 08:45 AM
Lo-Buck EF's Avatar
Default Re: half shaft install tricks? (Knestis)
day 2-i took the clips off that have to seat in the trans. the old one went right in. the new one went in as far as it did last night with the clip on. even tho they look the same and measure up, i think its the wrong one. i'm gonna take it back and get another one.
Old Aug 20, 2002 | 10:38 AM
Lo-Buck EF's Avatar
bingo. it was the wrong one. off my about a hair, ut it made all the differance
-spencer
Old Aug 20, 2002 | 07:35 PM
Knestis's Avatar
...it was the wrong one.
Dude - aren't you glad you didn't hit it?
K
Old Aug 20, 2002 | 07:47 PM
GSpeedR's Avatar
Nice save. I just had this problem as well (axles not going into tranny). However, I had the right axle. The outer splines on the outside of the clip had deformed somehow . I had to file those bitches for 20 minutes. It then went in without a huge fuss after I kicked the fenderliner (unrelated story or frustration and anger).
Glad you didn't have to resort to such tactics.
Old Aug 20, 2002 | 08:14 PM
M-EJ1's Avatar
I had this problem... it turns out I had the half-shafts reversed from left to right (right half-shaft on the left axle and vice-versa). Nice of Honda to put a large shoulder on the longer half-shaft so I wouldn't damage anything in my futile attempts trying to pound them in, all the while insisting that they were the right way around.
Don't be like me kids.... If someone suggests that something might be wrong, maybe you should check it before you force things.
Old Aug 21, 2002 | 04:12 AM
keithv's Avatar
Default Re: half shaft install tricks? (matt-eg)
ok ok, i should have added a disclaimer to my post about "persuading" the axle in.
DISCLAIMER
-make sure that everything fits correctly first. take off the snap ring and make sure the splines go all the way into the tranny and all the way into the hub.
END DISCLAIMER
Old Aug 21, 2002 | 07:44 AM
Lo-Buck EF's Avatar
yea, that was the tell tale thing that i did. i took the clips off and the incorrect one wouldn't go any farther than it had been.
-spencer
Old Aug 21, 2002 | 08:22 AM
downingracing's Avatar
Default Re: half shaft install tricks? (GSpeedR)
I had to file those bitches for 20 minutes. It then went in without a huge fuss...
Same issue here. No visible damage to the splines, but we filed them and it went right in.
Old Aug 21, 2002 | 12:57 PM
GSpeedR's Avatar
Default Re: half shaft install tricks? (downingracing)
downingracing: I see that you are from Pickerington (I'm from Westerville). Where to you go to race around here (track/HPDE-wise)?
Sorry for the thread hijacking.
edmek4
Apr 9, 2008 01:56 PM
hu
Mar 24, 2007 03:16 PM
LostAndFound
Jun 13, 2004 01:48 PM
biassj
May 16, 2003 03:57 AM
SC94DB8
Sep 10, 2002 12:48 PM
