FS: Stack 8100
Banned
From: at last finally back to sweet home, sunny north cali, usa
came off my civic hb. just freshly serviced from Stack with latest EPROM image and upgraded to 0-6-13000 rpm tach. comes with harness, you can reuse most factory sensors (rpm pickup, speed, coolent tmp)... has shift light, fuel presssure, water tmp, oil tmp batt voltage, lap timer (manual), warning lights... see http://www.stackinc.com/st8100.html for more info/spec.
the only thing wrong with it is the backlite function no longer works. they wanted like $350 to fix that which wasn't worth it.
$900 shipped. a new bare 8100 is $1398.00. mine also has the in car lap timer receiver $275. still need the track side beacon $275. and i need to call and find out but i think predictive lap timer might be in the system already 'cause i remember seeing the function on the dash ($750).
is any body interested? it's very nice to have for the race car 'cause you have everything right in front of you, and if something is out of parameter (user settable for high/low) you get a red warning light. so usually you only have to watch the tach (don't even need to with the shift light)...
[Modified by ghettoRacer, 12:24 PM 8/26/2002]
XXXRacing
Dec 18, 2004 04:39 AM
NegativeLift
Jul 8, 2002 09:57 AM
