Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Front dams and spliters
Old Dec 28, 2001 | 12:03 PM
RineRacing's Avatar
Default Front dams and spliters
What's the difference between front dams like Realtime ITRs use and a splitter like the one Roger Foo's civic uses? Visually I can see the difference but technically do they do the same thing? Also, are they only effective in road racing applications or would they be of some benefit in autoXing?
Old Dec 28, 2001 | 12:29 PM
maxQ's Avatar
Default Re: Front dams and spliters (Geratol)
Try this for background info: https://honda-tech.com/zerothread?id=91183
As for effect of a splitter while autoxing with a street car: zip, zero, and zilch. With a helping of nada.
Andy
Old Dec 28, 2001 | 03:06 PM
johng's Avatar
~used info from another source~
High pressure exists on top of the splitter, and low pressure exists beneath it. This adds up to a downward force on the splitter. This downward force is directly proportional to the surface area of the splitter. So, up to a point, the bigger the splitter is, the more downforce it can create.
Two photos of splitter implementations are shown below. Notice the enormous size of the splitter on the Panoz Le Mans car. On the Ford Mondeo BTCC car, we can clearly see the very narrow "venturi" section under the splitter. This speeds up the air flow and lowers the local pressure.
Some designers have maximized the use of a front spoiler venturi. On the 1996 DTM/ITC Mercedes Benz shown above, we notice that it does not have any kind of splitter. In fact, it has the opposite of a splitter. The lower portion of the spoiler curves back in towards the car, instead of jutting out into the stagnation region. The designers were trying to encourage the high pressure air in front of the spoiler to flow underneath the car. This way they could maximize the venturi effect underneath the front of the vehicle. In essence, the front spoiler region of the car forms a "mini ground-effect tunnel". In the "throat" region of the venturi, the air flow speeds up and hence the local pressure goes down. This creates downforce. The longer the throat region is, the more downforce that can be created.
A simplified schematic of the air flow over and under a racecar with a spoiler venturi is shown here:
There are many possible permutations of the splitter/venturi spoiler idea. Some racecars use either just a splitter or just a venturi. Other designers have attempted to combine the two devices in an effort to maximize front downforce under modern racing regulations (which usually require a flat under-body from the front axle-line back). Two examples of combined splitter-venturi designs are shown below. These Super Touring cars from the English and German series. Notice in particular that the Volvo S-40 has a splitter going right up and over the venturi inlet.
[Modified by johng, 4:08 PM 12/28/2001]
sdubfid
Welding / Fabrication
Nov 2, 2009 03:27 AM
bass6153
Sep 3, 2006 09:05 AM
MtnCRX
May 7, 2005 01:52 PM
EFSiR
Apr 1, 2005 03:15 PM
turboH22Aakkord
Jun 24, 2004 11:28 AM
