Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
fire systems
Old Nov 27, 2003 | 12:10 AM
vodomagoo's Avatar
Default fire systems
im looking into installing one once my cage is finished. i am intrested in the different types and pluses and minus's of halon and afff
Old Nov 27, 2003 | 02:15 AM
jc836's Avatar
Default Re: fire systems (vodomagoo)
The Halon system is a gas setup and requires NO cleanup after the event. The downside is that you must exit the car promptly since the Halon is toxic at worst, but stops Oxygen absorption for a short time. Cost is not cheap and you cannot refill the bottle yourself. It is highly effective in cars with the windows up and in underhood fire suppression.
AFFF is an excellent system as well. The positives are that it is completely non-toxic and does not impede breathing. You can recharge it yourself and there is no environmental impact either. The downside is that you will spend time doing cleanup. Cost is currently competitive with Halon and both systems use similar mechanical components and locations.
My all-time favorite, though messy, is Purple K. In the 2.5 pound handheld it is very effective but must be used once you are able to leave the car. Cleanup can be time consuming, but the stuff does its job.
A good 5 pound Halon or AFFF system will cost you ~$300. A Purple K extinguisher sells for under $50. Accessories are not considered in these numbers. Several sanctioning bodies virtually require the Halon/AFFF systems for good reason-they can be setup to trigger automatically or by means of a simple release handle. Another plus, using accessory devices is that these systems can be pointed at various parts of the car at the same time. Winston/Nextel Cup cars have 2 onboard units, with one specifically for the fuel tank area.
Happy Thanksgiving.
Old Nov 27, 2003 | 03:08 AM
philstireservice's Avatar
I sell an AFFF system. Go to philstireservice.com and then click on the FireCharger logo......I'm in Rockland also........Happy Thanksgiving......
Old Nov 27, 2003 | 06:40 AM
krshultz's Avatar
Default Re: fire systems (Maxx44)
The stuff Phil sells, from what I understand, is user rechargable
Everyone go eat some Turkey.
imzjustplayin
May 26, 2017 01:21 PM
soodominican
Audio / Security / Video
Nov 8, 2009 05:17 PM
BrianZ
22
Jun 29, 2004 02:01 PM
Warren
Aug 30, 2001 09:46 AM
