Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Fire Ext.. where to mount?
Old Oct 10, 2004 | 04:35 PM
gsober's Avatar
Default Fire Ext.. where to mount?
I do not have a roll cage and do not want to mess up the interior. what are my other options? I have a track day this sat. and just found out i need one. thanks
Old Oct 10, 2004 | 04:43 PM
ewaugh's Avatar
Default Re: Fire Ext.. where to mount? (gsober)
I've been trying to figure this out two and couldn't come up with anything short of drilling.
Old Oct 10, 2004 | 04:46 PM
slammed_93_hatch's Avatar
who are you running with? i haven't heard of NASA requiring fire ext for HPDE's??
Old Oct 10, 2004 | 04:51 PM
gsober's Avatar
Default Re: Fire Ext.. where to mount? (slammed_93_hatch)
the ferrari club. it stinks because the track we are using (summit point) does not require it...the club does.
Old Oct 10, 2004 | 05:49 PM
Crazydave's Avatar
remove the passenger seat, and use the hole and bolt from the seat mount for your fire extinguisher
Old Oct 11, 2004 | 03:31 AM
jc836's Avatar
Default Re: Fire Ext.. where to mount? (Crazydave)
Dav'e suggestion is part of the solution-use one of the mounting bolts for the passenger seat as an anchor point. Go to HD and buy a piece of steel stock and make a bracket that fits under the bolt-have the extinguisher facing forward toward the dash and the front of the bracket bent down 90 degrees so that it touches the floor.
This method keeps the passenger seat in the car
Good luck
Modified by jc836 at 11:18 AM 10/11/2004
Old Oct 11, 2004 | 07:05 AM
Sean O'Gorman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">remove the passenger seat, and use the hole and bolt from the seat mount for your fire extinguisher
What if he needs to keep the passenger seat in for an instructor?
Old Oct 11, 2004 | 08:12 AM
downingracing's Avatar
Mount the extinguisher on a piece of wood/lexan. Cut slots on each side. Use the center lap belt (hopefully you have one) to hold it in place. I've never done this myself, but I've seen it done many times. Good luck!
Old Oct 11, 2004 | 09:04 AM
mityVR6's Avatar
Default Re: Fire Ext.. where to mount? (downingracing)
Why does it stink to have extinguishers required in on-track cars? To some extent, I think we're all "lucky" (in the same sense) that they don't require full rollcages and firesystems. Anyway, you really don't want that thing becoming a missle if you have an incident. Bolt it to the floor in front of your passenger seat and pat yourself on the back for doing the job right.
Old Oct 11, 2004 | 09:12 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsober &raquo;</TD></TR><TR><TD CLASS="quote">the ferrari club. it stinks because the track we are using (summit point) does not require it...the club does.</TD></TR></TABLE>
really? I've run with them out here and they had no special requirements.. ::
sounds like there's some good suggestions in here for you though..
Old Oct 11, 2004 | 09:55 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downingracing &raquo;</TD></TR><TR><TD CLASS="quote">Mount the extinguisher on a piece of wood/lexan. </TD></TR></TABLE>
HELLO!!!!!
Old Oct 11, 2004 | 10:02 AM
Mike_C's Avatar
Default Re: Fire Ext.. where to mount? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
HELLO!!!!!</TD></TR></TABLE>
yeah! don't use wood... i heard magensium is mo better!
Old Oct 11, 2004 | 10:21 AM
It's just a track day. A car with a full interior has plenty of stuff to burn - the small piece of wood won't be a factor... And if you strap it in with the seat belt, it's not going to go anywhere.
Just my 2¢
Old Oct 11, 2004 | 01:16 PM
gsober's Avatar
i agree with everything that is above. i do want the fire ext. in the car for safety reasons but i am short on time. what stinks is the short notice ..not the fact of having a safety equipment.
grip200kg
Feb 10, 2009 03:16 PM
K2e2vin
Jun 9, 2008 07:41 AM
ungcobob
Sep 30, 2006 04:40 PM
EFin' Kyle
Feb 8, 2006 02:20 PM
Lo-Buck EF
10
Dec 23, 2002 11:32 AM
