Extended wheel stud help
I have a 92 CX hatchback and need to get some extended wheel studs on the front for my bogarts. im looking into ARP but I don't know how the sizes, etc. work
Which do I need?
Which do I need?
This was covered not too long ago. Try looking back a few pages.
The OE 1986-89 (?) Teg rear studs are apparently longer and fit the bore fine.
The GM size. The knurl is a lot bigger, so make sure you SLIGHTLY drill out the hub. You can just squash it in there, but it's not good for the hub, which already takes an assload of abuse.
12mm x 1.5mm is the one you are looking for. I forget the stud length, but it is way long.
Warren
Warren
