Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Dropping Into 3rd Gear
Old Jan 16, 2004 | 02:50 PM
SynTeg's Avatar
Default Dropping Into 3rd Gear
Just wondering how you guys Downshift to 3rd from 5th. i.e Rev to higher RPM then drop it or just drop it.
Old Jan 16, 2004 | 02:55 PM
Reid's Avatar
Global Moderator
Default Re: Dropping Into 3rd Gear (SynTeg)
I always try to shift from 5th to 3rd just before hitting the rev limiter.
FWIW, this is on an ITR so YMMV.
Old Jan 16, 2004 | 03:08 PM
vwong's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SynTeg &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering how you guys Downshift to 3rd from 5th. i.e Rev to higher RPM then drop it or just drop it.</TD></TR></TABLE>
Depending on the speed, I sometimes downshifted from 5th to 3rd. The key is to match the rev.
Old Jan 16, 2004 | 03:33 PM
SPiFF's Avatar
Rev match. I also put it into 4th, but not let the clutch out, then to 3rd. I have almost gone from 5th to 1st one too many times going into turn 1 at Roebling ~80MPH.
Old Jan 16, 2004 | 04:15 PM
John's Avatar
New User
Yep, heel toe it, and you should have no problem getting it into 3rd smoothly.
Old Jan 16, 2004 | 04:18 PM
Neo's Avatar
Neo
Default Re: Dropping Into 3rd Gear (SPiFF)
Hard to answer the question without knowing the circumstance under which you'd want to do this. Also depends on your speed. But, as others have said, if you rev match and are at a speed that doesn't exceed the limits of your third gear, then you should be fine.
Old Jan 16, 2004 | 04:57 PM
krshultz's Avatar
Are you braking (i.e., slowing for a corner) when you need to make this shift?
Old Jan 16, 2004 | 05:38 PM
SynTeg's Avatar
My mistake, I was refering to dropping into third from a roll not on a corner.
Old Jan 16, 2004 | 05:40 PM
.RJ's Avatar
.RJ
Default Re: (SynTeg)
from a roll?
07FG2
Honda Civic (2006 - 2015)
89
Jan 12, 2009 03:48 PM
Deathwish
19
May 27, 2005 03:41 AM
MTR.18
Mar 27, 2005 08:11 AM
98prelude98
Sep 4, 2004 09:29 PM
IgniteTeg
Aug 5, 2001 11:16 PM
