Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Difference in SS brake lines?
Old Mar 3, 2002 | 01:05 PM
Prelussion's Avatar
Default Difference in SS brake lines?
How much of a difference is noticable when using ss brake lines and dif brake fluid on stock rotors and calipers?
Old Mar 3, 2002 | 01:59 PM
Grumpy's Avatar
New User
Default Re: Difference in SS brake lines? (Prelussion)
stainless steel covered brakes lines don't expand so all your brake input goes directly to the brakes, with less mushy feel.
HP brake fluid won't boil as easily, preventing soft pedal.
for both mods.
Old Mar 3, 2002 | 02:05 PM
Prelussion's Avatar
Default Re: Difference in SS brake lines? (Grumpy)
thanks, and your not too far away from here. I'm in Western North Carolina. We're about to start auto-x season.
http://www.main.nc.us/HSCC/
theres the website for the local auto-x group. Come see us.
Old Mar 3, 2002 | 02:47 PM
dn's Avatar
dn
the squishy-ness just goes to the next weakest link. watch your brake master cylinder while you have a friend push the brake pedal and you will see what i mean. not very good bang for the buck really, but who am i to talk i have a set... if youre really itching to try something, i like the ol zip tie method better. fluid is a better investment as well as pads to match.. lap times will not improve with SS lines if the above two are in good order. sorry.
Old Mar 3, 2002 | 03:05 PM
Ponyboy's Avatar
Painting Masterpieces
Quite a bit of difference. You'll notice better modulation and feel with ss lines. A better brake fluid won't show it's value until you're on the track boiling regular fluid.
Old Mar 3, 2002 | 03:20 PM
Prelussion's Avatar
Default Re: Difference in SS brake lines? (Ponyboy)
i'll be autocrossing so i suppose the brake fluid won't make much of an improvement for me.
Old Mar 3, 2002 | 06:05 PM
Crack Monkey's Avatar
I little to no difference in feel when installed on my RX-7.
Brake fluid and pads do make a huge difference.
Also, SS lines are not so good on street. Dirt gets into the braid and can slowly erode the inner teflon tubing.
Old Mar 4, 2002 | 11:58 AM
Ponyboy's Avatar
Default Re: Difference in SS brake lines? (Crack Monkey)
Good point. Make sure to get the ss lines that have rubber covering the steel braid. Most come with this now so dirt won't eat away at the rubber in the interior.
Old Mar 4, 2002 | 12:16 PM
4doorH22's Avatar
I was not aware of this. My SS lines were coated, but the coating peeled away within a year (I guess not up to withstanding the heat levels).
Well that was 7 years and 90,000 miles ago. I will have to keep an eye on these lines though.
Old Mar 4, 2002 | 01:15 PM
maxQ's Avatar
They both turned blue.
Old Mar 4, 2002 | 06:02 PM
Prelussion's Avatar
Default Re: Difference in SS brake lines? (maxQ)
huh?
Old Mar 4, 2002 | 08:00 PM
Ponyboy's Avatar
Default Re: Difference in SS brake lines? (4doorH22)
Wow! 7 years - that's a record I think.
Since the coating melted off, you may want to change those out sometime soon.
Old Mar 5, 2002 | 04:20 AM
maxQ's Avatar
huh?
That's the only change I noticed.
Old Mar 5, 2002 | 05:12 AM
4doorH22's Avatar
huh?
If I may...
I think Prelussion was asking what turned blue?
I think MaxQ means the stainless lines and rotors turned blue?
Old Mar 5, 2002 | 05:23 AM
maxQ's Avatar
If I may...
The stainless lines have blue rubber stretched over the braid. The brake fluid was blue.
Old Mar 5, 2002 | 05:29 AM
4doorH22's Avatar
Oh, uhhhhh, well Brembo blanks sometimes get a blue haze.
And I figured SS lines could turn blue like a SS header does... but ummm no that's silly.
Old Mar 5, 2002 | 09:13 AM
ak-s2000's Avatar
Autocross events are not long enough to heat up the brake fluid to boiling point so it will not help also, s.s. lines will bump you out of stock class. Good brake pads will help a little but remember you don't brake that often when autocrossing. The brakes would be the last thing I would upgrade, my opinion.
Old Mar 5, 2002 | 06:05 PM
Prelussion's Avatar
Default Re: Difference in SS brake lines? (ITR_0207)
hell i put on an intake and got bumped out of the stock class so it doesn't matter to me.
Old Mar 5, 2002 | 06:17 PM
Conechaser's Avatar
i disagree w/ this, i've been autoxing for 3yrs now, and brakes are VERY important in my opinion. I could of prob dropped @ least .3 or so this last event, if i wasn't lazy and put on my Hawk pads, instead of using normal pads.
Also what good does it do to be able to gain .5 secs in the turns and short straights, if you have to break .8secs earlier?
Old Mar 6, 2002 | 06:06 AM
Prelussion's Avatar
Default Re: Difference in SS brake lines? (94Accord)
94 you still going to DG a lot? I need to make a trip up there sometime.
Old Mar 6, 2002 | 02:19 PM
VTEConly's Avatar
Don't brake that often when auto-xing? I guess it's safe for us to assume that you don't auto-x.. You brake a lot in auto-x. Brakes can make a big difference in your times. I dropped my times at least 1/3sec. or more when I went to AXXIS MM pads/Brembo blanks & SS lines (did it all the same day but I 'm sure pads helped the most) last year. I wish I had done them in '00 when I auto-xed on stock brakes the whole season.. You want to have better brakes so you can brake later instead of earlier on. Braking is very important in auto-x. Aftermarket pads would be the 1st thing I 'd do after tires, knowing what I know now.
[Modified by VTEConly, 6:23 PM 3/6/2002]
hteg12
Jul 18, 2013 05:13 PM
nb0
Jul 8, 2007 09:14 AM
tommyofyork
Apr 8, 2007 05:45 PM
citanest
18
Jul 6, 2001 01:41 PM
