Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Custom Window Net Source?
Old May 24, 2006 | 12:08 PM
thawley's Avatar
Default Custom Window Net Source?
Crow is no longer doing custom nets. Anyone know of a GOOD source for a custom sized window net for a Bonneville car?
Old May 24, 2006 | 12:26 PM
Andrie Hartanto's Avatar
teamtech
Old May 24, 2006 | 03:07 PM
117's Avatar
117
I had Pyrotect make me a custom Supernet.
http://www.pyrotect.com/produc...age=1
This was back when http://www.bellmotorsports.com was dealing with Pyrotect. Looking at Pyrotect's website, I couldn't find anything that mentions custom work, but if you like the Supernet, it's worth a shot.
Old May 24, 2006 | 07:31 PM
Chris F's Avatar
Default Re: (117)
Pegasus ordered mine, not sure who from.. you may want to try them.
Old May 24, 2006 | 08:34 PM
phat-S's Avatar
Default Re: Custom Window Net Source? (thawley)
Thawley, contact BSR Products in Concord/Charlotte NC (www.bsrproducts.com). You will need to send them a template (I did mine in construction paper) and allow two weeks from their Tuesday pickup. Its essentially a 3 week turn-around and should run between $75-100. $75 is the minimum, the price goes up w/ the complexity (mine had no two parallel sides and was 5 sided - bottom makes a bend). They are stamped w/ an SFI Cert and are made of the same netting as the standard nets they sell. You will want to print which side is in and which is out on your template (they'll explain).
If that doesn't work for you or you want mesh instead, you will want to contact Safe-Quip (http://www.safequipracingproducts.com) in South Carolina. There too you will want to provide a template and the turn around is about the same (and I believe the pricing is too - $50.00 + the cost of the mesh net). At the time I spoke to him, he wanted at least two parallel sides (which mine could not be).
Best of luck and if you can, don't get "too" too permanent with your mounting until the net arrives as the smallest eff-ups w/ your template will render the net itself a bit less useful than intended or you will be back to bending your net mounting bars. JME
Old May 25, 2006 | 04:49 AM
MarkosMotorsports's Avatar
John..
Because of my cage design I had a custom net done. M&R Products had it to me within three days. I was able to give them the shape and size by fax.
http://www.mrproducts.com/
Old May 25, 2006 | 05:13 AM
krbobcat's Avatar
Default Re: (Andrie Hartanto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">teamtech</TD></TR></TABLE>
Teamtech does all of mine.
Old May 25, 2006 | 05:19 AM
Chris F's Avatar
Default Re: Custom Window Net Source? (MarkosMotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkosMotorsports &raquo;</TD></TR><TR><TD CLASS="quote">John..
http://www.mrproducts.com/</TD></TR></TABLE>
Ahhh yeah. That's who Pegasus got mine from.
mr.vinhnguyen
Northwest
Apr 5, 2011 11:51 AM
.adam.
Mar 10, 2011 05:22 PM
rudebwoy
Nov 25, 2010 10:27 AM
bsiple
Audio / Security / Video
Jun 8, 2005 04:38 PM
chad
Jan 27, 2002 04:35 AM
