Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
CSP and obd conversion question
Old Aug 27, 2004 | 08:46 AM
crxgator's Avatar
Default CSP and obd conversion question
right now im in CSP and have a 91 crx si, i want to ultimately convert to obd1 use ITB and use a stock p06 ecu with hondata, im am reading the rules and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scca rulebook &raquo;</TD></TR><TR><TD CLASS="quote">
14.9 Electrical System
Any ignition setting adjustment or system may be used. An original ignition sensor on a cam cover may be removed, and the hole plugged. This may serve no other purpose. (3/2002) </TD></TR></TABLE>
does that mean i can have it tuned to the engines characteristics?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Wiring harnesses may not be removed in whole or in part. Wiring connectors for emissions control devices are considered part of the harness, not part of the emissions control system, and may not be removed. </TD></TR></TABLE>
there isnt anything saying about adding emissions though?
i would definatly like to know so when i do changes i dont get called a cheater or whatever for tring to go into a "lower" class...
Old Aug 27, 2004 | 08:49 AM
RineRacing's Avatar
Default Re: CSP and obd conversion question (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">right now im in CSP and have a 91 crx si, i want to ultimately convert to obd1 use ITB and use a stock p06 ecu with hondata,</TD></TR></TABLE>
That's all fine. You don't have to pass smog.
Old Aug 27, 2004 | 08:51 AM
crxgator's Avatar
Default Re: CSP and obd conversion question (RineRacing)
well id still be using the stock d16a6, i just figure it would be easier to get tuned and running properly with a good tuner and most use hondata, for that i have to be obd1...
Old Aug 27, 2004 | 08:56 AM
Todd00's Avatar
I said I don't want a title!
ECU, ignition, and intake are completely open in SP.
For instance, look at the 84-87 Civic/CRX guys running without the oem ECU with a full electromotive system that completely bypasses even the distrubutor.
Old Aug 27, 2004 | 09:09 AM
crxgator's Avatar
Default Re: CSP and obd conversion question (Todd00)
alright thanks for the quick answers...
Crack Monkey's Avatar
You should be fine as long as you don't remove any part of the stock wiring harness. IE, if you add a OBD1 harness, you'll have to leave the stock one there as well.
Old Aug 27, 2004 | 09:19 AM
crxgator's Avatar
Default Re: CSP and obd conversion question (Crack Monkey)
yup, i would buy the plug n play conversion harness and run the extra 6 wires to the engine bay...so i should be all good
motoxx644
Aug 1, 2007 03:36 PM
dohdoh420
Jan 22, 2006 01:59 PM
1blownnteg
10
Aug 4, 2004 01:06 PM
ComputerJLT
10
Feb 11, 2004 06:07 AM
5ltretr
Sep 18, 2003 05:44 PM
