Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Corner Balancing Help
Old Jun 23, 2018 | 05:36 PM
Dilbones's Avatar
Default Corner Balancing Help
Hey all. Long story short, my corner weights are F***ED.
I don't have access to a set of scales as of now but my thoughts are: lower the front driver and rear pass to 5.25 and 5.75 respectively. Thoughts? Will this work?
Additionally, any low-buck ideas to get the corner balance CLOSER to normal are appreciated.
FD = Front driver
FP = Front passenger
RD = Rear driver
RP = Rear passenger
Old Jun 23, 2018 | 08:17 PM
boxedfox's Avatar
Default Re: Corner Balancing Help
That would be a good start. Realistically it'll be very difficult to get your corner weights right without scales of some sort. I have a set of Ruggles' style lever scales if you have a flat work area and would like to give that a go.
Old Jul 20, 2018 | 12:51 PM
Dilbones's Avatar
So I will update this because maybe some troll will find my info useful. Basically I was overthinking the whole issue. If ride height from side to side (in rear or front) is off by 3/16" or less, that is to be expected. This is per a friend that used to work for Heinlein Racing Development in NJ.
As the above comments stated-- corner balance is more important than getting ride height set perfectly.
I was trying to get my ride heights even side to side with a tolerance <=1/16".
With that being said, i have had success with getting CLOSER to my overall ride height by using the method outlined in Hot Rod Magazine's Article shown below:
https://www.hotrod.com/articles/ctrp...corner-weight/
Scroll to the ESTABLISHING RIDE HEIGHTS SECTION.
Currently I'm toying with spring rate vs bar and setting my rebound correctly in the car...
Thanks all for the help.
ninja8oi
Oct 6, 2003 07:16 AM
-Whitey-
Dec 25, 2002 06:40 PM
