Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
A cheap data acquisition
Old Apr 4, 2005 | 11:49 PM
c4rip's Avatar
Default A cheap data acquisition
It seems someone is trying to put together their own data acquisition system check it out
http://www.justracing.com/raci...p?t=8
Would be cool if it actually works.
Old Apr 5, 2005 | 07:24 AM
GSpeedR's Avatar
Default Re: A cheap data acquisition (c4rip)
To answer your question about g-sensors on the control arms...It would be easiest to mount it directly to the upright, you are interested in the acceleration of the tire, not the control arm (more potential for error in tire g forces). Many teams use a combination of acceleration sensors (z-axis only is fine) on uprights in conjunction with linear position sensors at the shocks, which allows the shock velocity to be integrated and differentiated from two sources. The problem is that it can be frustrating to try converge data from two separate types of sensors.
You need at least a 10 g sensor, and you can use filtration to remove some of the noise that you will get. Also, the resolution of a sensor will depend on the sampling rate (dependent on your speed), so when the original poster claims the g-sensor has a higher resolution than a pot, I have to dissagree.
descartesfool
10
Sep 17, 2011 05:46 AM
descartesfool
22
Oct 20, 2005 04:04 PM
hoggy
Sep 29, 2003 06:22 PM
natesgarage
11
Sep 22, 2003 09:06 PM
natesgarage
Sep 22, 2003 09:10 AM
