Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Chassis data & calcs....
Old Nov 19, 2001 | 11:15 PM
RR98ITR's Avatar
Default Chassis data & calcs....
Here's a cleaned up version of some of my chassis data that I worked up for a fellow H-T member. Now that I burned up the night learning how to do more computer tricks here ya go:
Scott, who knows that this looks pretty bad....call it a relapse.....
Old Nov 20, 2001 | 11:01 AM
grippgoat's Avatar
Default Re: Chassis data & calcs.... (RR98ITR)
Does the word "Spreadsheet" mean anything to you?
I guess if I have to ask what all that stuff is, then I shouldn't bother squinting at it too much.
-Mike
Old Nov 20, 2001 | 11:27 AM
Warren's Avatar
Wrong-Way Wang
OMFG. You are my hero!
If you're ever on the east coast, come find me and I'll buy you a few beers.
Warren
Old Nov 20, 2001 | 11:38 AM
B18CXr's Avatar
very nice scott!!!!
Old Nov 20, 2001 | 11:43 AM
johng's Avatar
Default Re: Chassis data & calcs.... (B18CXr)
Wow. Very nice Scott. pretending to understand it all
Hey, for some reason I thought your ITR was yellow?
[Modified by johng, 12:45 PM 11/20/2001]
Old Nov 20, 2001 | 11:57 AM
AdamITR's Avatar
Default Re: Chassis data & calcs.... (johng)
Very impressive! Can you recommend some good reading material that can help a beginner understand all of this. Thanks!
Old Nov 20, 2001 | 12:56 PM
whitney's Avatar
One nit pick and a question:
Nit: When picking corner-weights, you assume the car weighs 2450#. Later in calculations for weight transfer, you used 2500. Or did I miss something? There. I feel better now
Question:
In the 380/250# cornering example, is it an assumption that max rear weight transfer will occur, bringing one rear wheel to 950# and the other to zero? I don't think that you can assume that. I bet there is less rear transfer and more front with such a soft rear spring. Inconsequential for the point you're trying to make, though!
Very compelling analysis, though! With accurate weight transfer information and tire slip-angle to force curves, you could get a numerical representation of oversteer/understeer. I've always wanted to do something like that
Old Nov 20, 2001 | 02:22 PM
fast-R's Avatar
New User
Scott - you're out of control. What's the "real world" use for this kind of stuff?
Old Nov 20, 2001 | 07:59 PM
GSRMatt's Avatar
25 Year Member
Default Re: Chassis data & calcs.... (fast-R)
Did you take the arms off and measure the pick-up points? If you did send the (x,y,z) coordinates to me, and the hight of the spindle, and I can plot camber curves and bump steer with a program I have.
Or email me and I'll send you the program, its pretty small and simple but effective.
Old Nov 20, 2001 | 10:23 PM
DB2-R81's Avatar
25 Year Member
Default Re: Chassis data & calcs.... (GSRMatt)
Hey Scott,
This page may help some of your readers understand some the numbers.
http://www.e30m3performance.com/tech...e/eff_rate.htm
[Modified by DB1-R81, 11:26 PM 11/20/2001]
Old Nov 21, 2001 | 06:21 AM
krshultz's Avatar
To give an idea of things like camber curves - as they relate to bump and to body roll. Which in turn helps me understand why the stiff rear springs on track-prepared Hondas are so effective.
Karl, who votes for Scott as our member of the year...
Old Nov 21, 2001 | 07:49 AM
RR98ITR's Avatar
Default Re: Chassis data & calcs.... (krshultz)
Adam - start with Puhn's "How to make you car handle".
Mike - 1) You caught me! That 50lb diff is an error. 2) You're right about the assumption about weight transfer (unless the soft rear has a really big swaybar). I thought it irrelevant to the purpose too.
Matt - I posted that data before.....geez, do a search.....oh, yeah, that won't work - there's nothing left to search in....I'll post some detail on that next week as well as the roll center sheets which are interesting too.
Scott, who will also finally post some pictures of his humble brake duct/diverters....
Xtream_V
Mar 23, 2009 07:41 PM
six sigma racing
Welding / Fabrication
25
Jun 9, 2008 08:46 AM
Caretaker
May 8, 2008 06:11 AM
