Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Caster
Old Mar 14, 2006 | 05:46 AM
vinuneuro's Avatar
Default Caster
1. How much difference in caster between each side is usually acceptable?
2. Can you go over the service limit without hurting too many things? How much over?
Old Mar 14, 2006 | 06:09 AM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
Default Re: Caster (vinuneuro)
is this for Prelude in your signature? Usually want caster to be equal side to side. If not, car can pull to the side with the "lower" caster reading. Looks like Prelude has strut rods like my CRX. If so, you could check to see if there is an aftermarket kit available. otherwise, you can try to cut down the strut rod bushings to gain caster
Old Mar 14, 2006 | 06:14 AM
vinuneuro's Avatar
Default Re: Caster (o-man)
No, Honda makes diff length radius rods to adjust caster for the SH, no shims. Is .5-.6 degree too much difference?
Old Mar 14, 2006 | 07:29 AM
o-man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote"> Is .5-.6 degree too much difference?</TD></TR></TABLE>
That may cause it to drift/pull to the side with the lower reading. Do you know if car has been wrecked?
Old Mar 14, 2006 | 08:58 AM
WRXRacer111's Avatar
For a EF-type radius rod suspension, is there a Honda-allowance for an adjustable radius rod to cure left-right imbalances? I guess it wouldn't be a "crash bolt", but a "crash rod"?
Old Mar 14, 2006 | 09:24 AM
solo-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">No, Honda makes diff length radius rods to adjust caster for the SH, no shims. Is .5-.6 degree too much difference?</TD></TR></TABLE>
not a problem. a good alignment shop will adjust the thrust angle and the car will track perfectly straight. .5-.6 cross caster is actually damn good for a production car.
nate
Old Mar 14, 2006 | 02:05 PM
vinuneuro's Avatar
Default Re: Caster (solo-x)
In terms of steering effort/directness, there would still be a difference right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x &raquo;</TD></TR><TR><TD CLASS="quote">not a problem. a good alignment shop will adjust the thrust angle and the car will track perfectly straight. .5-.6 cross caster is actually damn good for a production car.
nate</TD></TR></TABLE>
Old Mar 14, 2006 | 05:06 PM
o-man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">In terms of steering effort/directness, there would still be a difference right?</TD></TR></TABLE>
nope
national123
Jul 8, 2007 03:33 PM
integra15
Aug 25, 2006 12:28 PM
Wraith
10
May 2, 2005 06:54 AM
rice r0cket
Mar 15, 2004 10:13 PM
Kwuaymaikrup
Apr 10, 2003 08:02 AM
