Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
camber setting
Old Aug 2, 2004 | 10:07 AM
topsecret's Avatar
Default camber setting
what's up i just bought a camber kit and i was wondering what would be a good setting? i was thinking of going with a -1.5. any suggestions etc...?
thank you
peace
topsecret
Old Aug 2, 2004 | 10:08 AM
MattD@Stoptech's Avatar
Default Re: camber setting (topsecret)
stock is good.
Old Aug 2, 2004 | 10:59 AM
Blue Si #72's Avatar
It all depends on what you want the car to do.
For autocross I run 1.9 front and 1 rear on my '00 Si.
Maybe you should specify what you plan to run your car in (Autocross, road racing, etc) and what kind of car it is.
Old Aug 2, 2004 | 11:03 AM
topsecret's Avatar
Default Re: camber setting (Blue Si #72)
my bad
i plan on doing both auto cross and road racing
the kit i hav only goes to a 1.75 either way
that's why i was thinking -1.5
peace
topsecret
Old Aug 2, 2004 | 11:04 AM
Littleton's Avatar
-4, and my Civic rotates better than before.
Old Aug 3, 2004 | 06:21 AM
DX Hybridizer's Avatar
Default Re: camber setting (Littleton)
I do road track racing, and a very occasional auto X. I run -2.3 front -1.5 rear. It's a good starting point for a track car in my book. Corner speeds have greatly increased.
Old Aug 3, 2004 | 06:25 AM
topsecret's Avatar
Default Re: camber setting (DX Hybridizer)
thank you
my kit only goes to 1.75 so i'll probably go with 1.75 up front and 1.5 in rear or would having them all the same be a better way to go?
thank you again
peace
topsecret
Old Aug 3, 2004 | 08:46 AM
Forgot to say for the least uneven tire wear. No toe as well.
1.75 will not create excessive inner tire wear. toe will indeed.
Personally just from messing with mine I typically put less in the rear than what I run in the front. This is personal but at that level, you should be ok with the handling.
Old Aug 3, 2004 | 08:48 AM
topsecret's Avatar
thanks
peace
topsecret
DaveSi677
Honda Civic (2006 - 2015)
199
Nov 18, 2017 02:20 AM
Baller111
Suspension & Brakes
14
Jul 10, 2012 11:44 AM
acmoc
Dec 1, 2008 03:58 PM
s2k_3.11
Dec 1, 2006 11:09 AM
98dc2itr
Mar 16, 2003 12:10 PM
