Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake Squeaking
Old Sep 18, 2002 | 05:05 PM
OEMaccord's Avatar
Default Brake Squeaking
My brakes were fine until after a weekend of hard braking. Now my brakes sound like a school bus stopping. Is there anyway to make the brakes squeal less? I have Hawk HP+, is squeaking just a characteristic of these pads? I made sure to apply brake grease between the shims and pad when I installed them too.
Old Sep 18, 2002 | 07:37 PM
Madracer1's Avatar
Default Re: Brake Squeaking (OEMaccord)
Squak? They SQUEAK!!!! Nothing you can do about it, is the design of the pad like you said.....Gotta sacrifce comfort level for performance
Old Sep 18, 2002 | 07:50 PM
Type Goch's Avatar
New User
Do you still have the squeal tabs on em?
Old Sep 19, 2002 | 12:36 PM
OEMaccord's Avatar
Default Re: Brake Squeaking (Type Goch)
I dunno, what do they look like? Those circular things on the backing of the pad?
Old Sep 19, 2002 | 12:53 PM
nsxtasy's Avatar
H-T Order of Merit
The squeal tabs are a metal tab that touches the rotor when the pad material is worn down to where they need to be replaced. Some pads (including most stock pads) have them, some aftermarket pads don't.
Have you checked the thickness of the pads? It's possible that you need to replace them.
Old Sep 19, 2002 | 02:04 PM
OEMaccord's Avatar
Default Re: Brake Squeaking (nsxtasy)
They are a week old. So i dont think they are the wear indicators. I only put 60-70 track miles on them so I dont think that would wear them out to the indicators.
Old Sep 19, 2002 | 05:58 PM
nsxtasy's Avatar
H-T Order of Merit
Yeah, you're right. Maybe those pads just squeak and there's not much you can do about it.
Did you try putting anti-squeal goop on the back of the brake pads when you changed them?
Old Sep 19, 2002 | 06:16 PM
OEMaccord's Avatar
Yeah i forgot to do that when i installed them, put that stuff on, it went away, then ran at the track last weekend, then began squealing. I guess that stuff could have burt off. I guess I just hafta live with everyone starring at me thinking Im the bus as i come to a stop in the middle of campus.
Old Sep 19, 2002 | 10:53 PM
Kamin's Avatar
ding ding ding we have a winner!
im using axxis ultimate pads and i had to do a rotor change a couple days after i did my pads and well they didnt squeal before but they did after the rotor change, why? because i didnt use any antisqueal grease crap.
Old Sep 20, 2002 | 09:30 AM
nsxtasy's Avatar
H-T Order of Merit
Try putting more of that stuff on. You've got nothing to lose except a half hour or so of your time.
Old Sep 20, 2002 | 09:36 AM
martini's Avatar
they are going to squeek. there really isn't any getting around that. Just get used to it.
Try pumping the brakes once or twice when they are squeeking, sometimes that helps me..
Old Sep 20, 2002 | 09:51 AM
Watkinsm3's Avatar
Listen to everyone that said they are going to squeek. Its what those pads do. I run the HP+ and except for when I'm REALLY on the brakes they squeek. Every one I've talked to has this... Just wait till you see the amount of dust that they put out!
Old Sep 20, 2002 | 11:00 AM
Aron Parsons's Avatar
Default Re: Brake Squeaking (Watkinsm3)
aside from anti-squeek, when you wash your car, spray into the brake pads/calipers. this will remove brake dust and can often stop squeeking after some hard braking. my brakes squeek horribly after an auto-x, but after i spray out the dust, the squeeking is gone (until the next event that is).
Old Sep 20, 2002 | 11:08 AM
Neo's Avatar
Neo
Hawk HP+s: run them, love them, great autocross pad, the dust from these SOBs will own you, say goodbye to ever having clean wheels on your car again...
and yes, they squeek
mickey513
Nov 16, 2018 03:56 PM
jlowellintegra
Dec 23, 2010 09:46 PM
faSHOwidIT
Apr 18, 2005 02:06 AM
Chris y0!
10
Jan 8, 2003 09:14 PM
sIcWiTiT
Sep 26, 2002 12:28 PM
