Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
BMW Bolt pattern and offset on teg?
Old Mar 11, 2003 | 02:15 PM
JSR3STS's Avatar
Default BMW Bolt pattern and offset on teg?
No clue if they fit
Kosei Wheels Posted: Jan, 13 2003
Six 15x7 Kosei wheels with used 205x50x15 Kumho victoracer tires. Used only one season. Tires would be good for school.
Currently running on BMW. Changing car to a E Production racer. Sell all 6 for $600 plus shipping
Sounds good but dont know , dont think it fits a teg
Old Mar 11, 2003 | 02:22 PM
JSR3STS's Avatar
Default Re: BMW Bolt pattern and offset on teg? (JSR3STS)
nevermind,, found my answer, they dont....
off if IT though someone may want them
Old Mar 11, 2003 | 05:46 PM
jg's Avatar
jg
You probably figured this out already...but for everyone else...later BMW's have a 5x120 bolt pattern, while the normal 'tegs are 4x100 and the "R" is 5x114.3. The Bimmer's offset is much closer to zero than the front drive offset of the Honda's.
Old Mar 11, 2003 | 05:55 PM
Catch 22's Avatar
Default Re: BMW Bolt pattern and offset on teg? (jg)
Some earlier BMWs did have a 4x100 bolt pattern. Don't know the exact years, but if you look hard enough you can score nice stock BMW BBSs that will fit. 14x6 and 15x7 I think.
Not positive on sizes and widths.
Old Mar 11, 2003 | 07:06 PM
mos's Avatar
mos
Default Re: BMW Bolt pattern and offset on teg? (Catch 22)
The 3 series cars before 1992 had a 4x100mm bolt pattern. I'm not sure of the exact years. I'm not sure about the center hole diameter either, but you may have to machine it out if it is too small. Some of the OEM BMW wheels are very light, and if you can find them for cheap, they may be a good bargain.
Old Mar 11, 2003 | 07:24 PM
SPiFF's Avatar
E30 (non M3) had 4x100 but the offet is something like 27.
Old Mar 11, 2003 | 07:40 PM
mos's Avatar
mos
Default Re: BMW Bolt pattern and offset on teg? (SPiFF)
Wow, I had no idea the offset was that low, are you sure SPiFF? I have pictures of some 1990 BMW bottlecap 14's on an Integra, and it doesn't look like they are sticking out of the fenders. Maybe he machined them to alter the offset or something. I remember he said they were less than 11 pounds each. VW also has some nice 4x100mm OEM wheels, but I'm unsure about offset or center hole diameter on those also.
Old Mar 11, 2003 | 08:15 PM
whitney's Avatar
83-91 E30 318i, 318is, 325, 325e, 325es, 325i, 325is, 325ix used 4x100 wheels
318i, 325, 325e, and 325i came with 14x6 bottlecaps or steelies with 35mm offset
318is, 325es, 325is (and rare 91 325i with sport pack) came with 14x6.5 BBS mesh wheels with 30mm offset
325ix is the bastard with 15x7 and high (41?) offset
Proper offset for a 15x7 wheel on an E30 non-M3 non-ix is about 25-27.
Old Mar 12, 2003 | 06:21 AM
jg's Avatar
jg
Default Re: BMW Bolt pattern and offset on teg? (whitney)
nice info guys
Old Mar 12, 2003 | 06:34 AM
jsi's Avatar
jsi
Yeah, i have the 14x6.5 ET30 BBS rims on my G1 Teg. Fits perfect other than the larger center bore, so i just torque them off the ground, no big deal. I run 205-55-14 but can probably stuff a 225-50-14 in there easywith that offset and no need for spacers. Also they are relatively light, under ~12lbs or so...
Old Mar 14, 2003 | 06:47 AM
Jake's Avatar
Default Re: BMW Bolt pattern and offset on teg? (jsi)
If I wasn't so cheap, I'd buy these for myself as spares. I'll let you guys benefit my hard web searching. As of 3/13 he still has them, he sent me pics, they look good.
http://www.roadfly.org/bmw/classifie....php?view=5130
buymesomedunks
Aug 21, 2012 03:56 PM
dukers
Jul 18, 2005 09:45 PM
mr_mbuna
Jul 11, 2002 10:30 AM
b18a1
Oct 2, 2001 01:11 PM
