backing plates
does anyone know what the specs are on teh packing plates for harness mounting hardware? i got eye bolts, but ho backing plates...again
and if i can, im just gonna go ahead and make them.
tia
-spenc
and if i can, im just gonna go ahead and make them.tia
-spenc
Most of the ones I have bought are about 2.5" in diameter and 1/8" thick. You can by them from Simpson and other harness makers like M&R. Then again check with a Fastener supply house.
ye, the only reason i want to make them is beacuse everytime i try to order them, i get screw'd and end up with everything else BUT the backing plates
-spenc
-spenc
found it
4” x 4” x 1/8” steel plate with pre-drilled hole. Required by SCCA and highly recommmended when mounting hardware directly to body of car.
Andrew 825SM
Dec 19, 2002 12:50 PM
B19CivicHB
Sep 22, 2002 06:46 PM
norice
Apr 26, 2002 05:29 PM
