Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
B&M Relocation fitting is crap!
Old Jul 8, 2003 | 08:18 AM
teg92's Avatar
Default B&M Relocation fitting is crap!
I've tried sealing those damn fittings with thread sealant, teflon tape etc, but those things always leak. Any recommendations?
I'd like to get a top notch quality set of pieces for my oil filter relocation setup. I need the fitting that goes on the block and the fitting that actually holds the filter. I already have hose and AN-8 fittings along with a good oil cooler.
Anyone know where I could purchase these fittings without the entire kit?
Thanks
Old Jul 8, 2003 | 09:57 AM
Geezer's Avatar
Default Re: B&M Relocation fitting is crap! (teg92)
http://www.pegasusautoracing.com/
Old Jul 8, 2003 | 11:14 AM
teg92's Avatar
Default Re: B&M Relocation fitting is crap! (Geezer)
Those adapters look identical to the ones in the B&M kit!
Old Jul 8, 2003 | 01:00 PM
johng's Avatar
You probably already know this, but be sure you wrap the teflon tape in the direction the fitting will thread. Otherwise it'll unravel as you thread on the female fitting and leak.
$.02
Old Jul 8, 2003 | 01:48 PM
ruthless013's Avatar
i just received a jegs catalog that i think has the part you need and sells it seperately.
http://www.jegs.com
hth
Old Jul 8, 2003 | 02:57 PM
teg92's Avatar
johng: Thanks but I already did that!
ruthless013: Thanks the only one that looks interesting is the moroso piece but I don't quite understand what the top fitting is for?
The Perma-Cool mount they have as well looks quite good but a little pricey.
But then again anything has got to be better quality metal than that of the B&M/PermaCool/TD/Summit kits...
I'm so damn scared to tighten that thing too much and watch the adapter crack.
Old Jul 8, 2003 | 05:25 PM
krshultz's Avatar
Default Re: (teg92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg92 &raquo;</TD></TR><TR><TD CLASS="quote">ruthless013: Thanks the only one that looks interesting is the moroso piece but I don't quite understand what the top fitting is for?</TD></TR></TABLE>
Looks like it's just an extra hole. You could plug it, or put a gauge sensor in it. Nice easy place to put an oil temp or oil press gauge sender.
Old Jul 8, 2003 | 11:01 PM
Want2race's Avatar
Default Re: (krshultz)
http://www.racerspartswholesale.com
Old Jul 9, 2003 | 08:45 AM
teg92's Avatar
Default Re: (Want2race)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Want2race &raquo;</TD></TR><TR><TD CLASS="quote">http://www.racerspartswholesale.com</TD></TR></TABLE>
dead link
Old Jul 15, 2003 | 04:34 PM
Geezer's Avatar
I was looking through the Pegasus catalog tonight, and it appears that the fittings that go into these adapters are usually 1/2" BSP (British Standard Pipe) male fittings. They do not seal on the thread or the flare at the end of the fitting, but on the shoulder at the upper end of the threads. This appears to be done by a 1/2" O-ring or an aluminum crush washer. Maybe you should try this before trashing the adapters.
Old Jul 16, 2003 | 10:00 AM
rolow's Avatar
http://www.cantonracingproducts.com
Old Jul 16, 2003 | 10:19 AM
mityVR6's Avatar
Default Re: B&M Relocation fitting is crap! (rolow)
http://www.batinc.net/main.htm
Old Jul 16, 2003 | 10:29 AM
Shortbus's Avatar
I agree with rolow... the Canton stuff is the ticket&gt;
http://www.cantonracingproduct...#cast
Old Jul 16, 2003 | 11:14 AM
teg92's Avatar
UPDATE: I got around to redoing the same problematic fitting, and found that the thread sealant I applied last time never really cured. I redid the fitting with about 3 rounds of teflon tape and then sealed the last 2 threads with thread sealant. Tightened it like a bitch and no leaks.
I will probably be replacing the fitting when I switch over to stainless hose etc. But until then I've still got to fix the leak on the block adapter as well.
Thanks everyone for the help.
Old Jul 16, 2003 | 02:31 PM
NINJASPY's Avatar
Default Re: (teg92)
http://www.racerpartswholesale.com/
EJ8 GSR-T
May 28, 2008 06:54 PM
Flexin5
Sep 20, 2006 12:05 PM
PearlWhiteAccord
Aug 5, 2004 12:59 PM
greebler
Feb 18, 2003 03:51 PM
cyan1de
Feb 25, 2002 12:44 PM
