Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Axle/Coilover Question
Old Oct 26, 2002 | 09:37 AM
brasilracing's Avatar
Default Axle/Coilover Question
I have just recently started experiencing that thump-thump sound that you hear with the cv joint/axles go bad. However, it doesn't occur all the time and it doesn't happen when I turn either left or right. It only happens when I make a light stop in a straight line and as stated it doesn't consistently happen. I have GCs w/koni yellows - could it be my coilovers making that popping sound? Any suggestions? Thanks in advance.
Old Oct 27, 2002 | 11:30 AM
Aron Parsons's Avatar
Default Re: Axle/Coilover Question (brasilracing)
well, it's definetly not your axles if it's inconsistent and doesn't happen when you turn. bad CV joints' indicators are a consistent clicking sound when turning at low speeds. it could likely be your springs/shocks, but i'd check the whole front suspension to be safe (also, brakes). made sure everything is torqued to spec, check for worn bushings as well. i'd think a worn bushing could produce a thumping sound, as things hit that shouldn't hit due to the lack of rubber padding of a bushing.
Old Oct 27, 2002 | 12:08 PM
JeffS's Avatar
check your wheel bearings.
Old Oct 27, 2002 | 02:33 PM
krshultz's Avatar
Default Re: Axle/Coilover Question (JeffS)
And the ball joints.
Old Oct 28, 2002 | 05:55 AM
Thanks, I will have those areas checked out.
ak1059
Sep 17, 2010 05:12 PM
egjake
Jan 3, 2010 07:18 PM
ivan93egreppin210
Aug 2, 2009 09:48 PM
badson
Dec 11, 2004 04:51 PM
hyperlite1080
11
Apr 14, 2004 08:24 PM
