Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Antenna Delete Panel
Old Apr 26, 2004 | 09:26 AM
Crosser's Avatar
Default Antenna Delete Panel
I have removed the stereo system from the CRX (second gen), I want to order the blank plastic plate that fills the antenna hole on the roof so I can remove the antenna. I have gone to the local dealer and we did a serious search and could not find this part in their system. I was wanting to know if any of you out there have a part number I can give them to help in the search?
I did a search and could not find anything.
Thanks,
Eric
Old Apr 26, 2004 | 09:51 AM
MightyMouseTech's Avatar
Default Re: Antenna Delete Panel (Crosser)
You need a new parts guy
39152-594-004 CAP, ROOF SEAL
39153-SB6-000 WASHER, SEAL CAP
Or a hunk of duct tape works too.
Old Apr 26, 2004 | 10:02 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Antenna Delete Panel (MightyMouseTech)
damn, mighty mouse beat me to it..... it is listed under 88 honda crx hf. tell the guy to look under "speaker seal bracket" and the pic will come up.
Old Apr 26, 2004 | 10:06 AM
thawley's Avatar
Default Re: Antenna Delete Panel (rodney)
Damn. You guys are smart.
Are the part numbers the same for 88-91 Civic Hatch, as well?
Thawley
Old Apr 26, 2004 | 10:40 AM
Crosser's Avatar
Default Re: Antenna Delete Panel (thawley)
Ah, I can't knock the guy too bad. He sat there and searched with me standing there for about 20 min. It was definitely not in the spots you would expect it too be.
Thanks though.
Old Apr 26, 2004 | 03:44 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crosser &raquo;</TD></TR><TR><TD CLASS="quote">Ah, I can't knock the guy too bad. He sat there and searched with me standing there for about 20 min. It was definitely not in the spots you would expect it too be.
Thanks though. </TD></TR></TABLE>
It's listed the same for all 88-91 CRX as well as all 88-91 Civic. If he was a good parts man, on his down time he would go through the system and just point and click to familiarize, just for little instances like this. Honda puts stuff in straaaaange places.
Jim - who pictured the exact spot and location this part was in and thought "speaker seal bracket" as soon as I read the title and knew you needed the base, the plate and two screws all sold separately.
Old Apr 27, 2004 | 05:37 AM
cspCRXsi's Avatar
Default Re: Antenna Delete Panel (Mr Milano)
So is there a radio block-off plate for the dash also? If so, is it available?
Old Apr 27, 2004 | 06:27 AM
Crosser's Avatar
Default Re: Antenna Delete Panel (cspCRXsi)
Yes, I can give you the part number tonight.
Old Apr 27, 2004 | 06:54 AM
cspCRXsi's Avatar
Thanks!
Old Apr 27, 2004 | 07:08 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cspCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">So is there a radio block-off plate for the dash also? If so, is it available?</TD></TR></TABLE>
77230-SE3-A02 RADIO PANEL ASSEMBLY
Comes with the clip too.
Old Apr 27, 2004 | 07:44 AM
carl_aka_carlos's Avatar
while on this subject is there a block off plate for the antenna on 94 Integra's? some dick broke mine off and i don't feel like putting another one on.
Old Apr 27, 2004 | 08:24 AM
robbin's Avatar
Default Re: Antenna Delete Panel (carl_aka_carlos)
Is there a block off plate for the driver? The one in my car hasn't been working very well lately so I'm thinking of removing it.
Old Apr 27, 2004 | 09:06 AM
Geezer's Avatar
You guys are just too pimpy.
I just pulled the antenna out of the holder, rolled up a ball of the good old tar-like seam sealer, and stuffed it in the hole. Hasn't leaked for a year and a half.
Old Apr 27, 2004 | 09:15 AM
RineRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carl_aka_carlos &raquo;</TD></TR><TR><TD CLASS="quote">while on this subject is there a block off plate for the antenna on 94 Integra's? some dick broke mine off and i don't feel like putting another one on.</TD></TR></TABLE>
IIRC there is a rubber plug for the antenna hole.
Old Apr 28, 2004 | 06:12 AM
Crosser's Avatar
Default Re: Antenna Delete Panel (Geezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geezer &raquo;</TD></TR><TR><TD CLASS="quote">You guys are just too pimpy.
I just pulled the antenna out of the holder, rolled up a ball of the good old tar-like seam sealer, and stuffed it in the hole. Hasn't leaked for a year and a half. </TD></TR></TABLE>
No technically to be legal in SP, you have to have the block off plates if the items are removed.
Old Apr 29, 2004 | 10:57 AM
racerjon1's Avatar
Same with me in Stock class. I had to go order the stuff for my first gen to be "legal" (also have to remove it all..cant take the radio without the antenna..etc)
Jon K
http://www.seat-time.com
Old Apr 29, 2004 | 11:32 AM
preparedcivic's Avatar
Default Re: Antenna Delete Panel (racerjon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crosser &raquo;</TD></TR><TR><TD CLASS="quote">No technically to be legal in SP, you have to have the block off plates if the items are removed. </TD></TR></TABLE>
Not necessarily. Radios are specifically listed as comfort and convenience items not bound by the Stock Category restrictions which carry into SP. A protest committee might disagree, but having been on a few...... In any case, stuff like relocated windshield washer bottles because that's where the updated because onthe same line power steering pump goes has historically only netted a slap on the wrist. But, better to be **** than shat on!
When I built my ratty tatty EP car, I went to the trouble of cutting a nice piece of aluminum, and used the original antenna gasket and screws to hold it down. Still looks pretty spiffy 9 years later.
Old Apr 29, 2004 | 12:28 PM
Crosser's Avatar
Default Re: Antenna Delete Panel (preparedcivic)
I thought with the new radio delete rule, that you had to cover the radio opening. I may be mistaken, but it is not a big deal. I want to cover it anyway.
Old Apr 29, 2004 | 07:13 PM
JCracer723's Avatar
would anyone be interested on a cf block-off antena plate ?
Old Dec 13, 2005 | 04:23 PM
thirteen20CRXSi's Avatar
Default Re: Antenna Delete Panel (JCracer723)
how much for the carbon fiber one
Old Dec 13, 2005 | 04:59 PM
fireant's Avatar
wahat a coincidence, I just shelled out $21 for a blockoff plate for my stereo and antenna yesterday.
In STS2 you want the car to be weenie-protest-proof!
Plus its a good excuse to create some crazy removable-stereo-and-speakers-in-a-box-with-a-handle contraption... oh, wait, dont they have those at wal-mart?
Old Dec 14, 2005 | 08:17 AM
Andy Hollis's Avatar
Default Re: Antenna Delete Panel (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">wahat a coincidence, I just shelled out $21 for a blockoff plate for my stereo and antenna yesterday.
Plus its a good excuse to create some crazy removable-stereo-and-speakers-in-a-box-with-a-handle contraption... oh, wait, dont they have those at wal-mart?</TD></TR></TABLE>
Wish you had said something, I have an extra radio plate I could have brought to SASCA's event on Sunday.
--Andy
NOFX
Dec 12, 2014 01:20 PM
holdenw172
Honda Civic (2001 - 2005)
May 15, 2010 11:06 AM
itr1235
Mar 30, 2006 08:05 PM
ham
Jul 22, 2005 08:43 AM
