Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Alignment settings recommendations (for an Integra)...
Old Nov 10, 2004 | 05:01 AM
whereuat's Avatar
Default Alignment settings recommendations (for an Integra)...
If you guys could help out asap, that'd be great. I have to get back to the guy doing my alignment, so I need to get him specs. Here's my current setup:
1994 Acura Integra GS-R
Stock front and rear sway bars (24mm/14mm)
-looking to upgrade to a 22mm in the rear very soon
Koni OTS Sport Yellow shocks
Ground Control coilovers w/ 450F/600R spring rates
Ground Control upper shock mounts
15"x7" Rota Slipstreams
Falken Azenis
I called Ground Control and they suggest 2.0F/0.5-1.0R (all negative camber of course) with 0-1/4" toe out in the rear. Any other suggestions? Should I go for 0 toe in the front?
Please advise. Thanks!
Old Nov 10, 2004 | 06:19 AM
.RJ's Avatar
.RJ
Default Re: Alignment settings recommendations (for an Integra)... (whereuat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whereuat &raquo;</TD></TR><TR><TD CLASS="quote">Please advise. Thanks!</TD></TR></TABLE>
Search please - this topic has been covered quite a bit.
Old Nov 10, 2004 | 06:28 AM
whereuat's Avatar
Default Re: Alignment settings recommendations (.RJ)
The reason for my asking is because of my particular setup. One question is this: Should there be more toe out in the front than the rear? Or vice versa?
Old Nov 10, 2004 | 06:43 AM
Xian's Avatar
Default Re: Alignment settings recommendations (whereuat)
depends personal preference and on how much you want your tires to wear... also, is this a daily driver? If it is, then I'd just go with zero toe all the way around and get a bigger rear bar.
As always, just my $0.02
Christian, who'd probably put the 600# springs up front and the 450's in the rear...
Old Nov 10, 2004 | 07:22 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whereuat &raquo;</TD></TR><TR><TD CLASS="quote">The reason for my asking is because of my particular setup.</TD></TR></TABLE>
Your setup isnt any different than most track/autox integra.
Old Nov 10, 2004 | 07:46 AM
johng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whereuat &raquo;</TD></TR><TR><TD CLASS="quote"> with 0-1/4" toe out in the rear. </TD></TR></TABLE>
Good luck with that.
Since you don't have adjustable arms, shoot for 1.5 - 2.0 neg camber (without running out of shock travel), and if it's a street car, set toe to factory spec.
Old Nov 10, 2004 | 11:54 AM
BrianZ's Avatar
On my H4 car I run a simular suspention setup
3.5 deg neg in front
2.5 deg neg in rear
0 toe all the way around.
I would not suggest running that on the street tho!
Project Phoenix
Honda CR-V & Element
35
Jan 30, 2015 06:38 PM
sonntag
Mar 10, 2011 07:57 AM
racing_reject_001
Suspension & Brakes
May 6, 2010 03:04 AM
Playerz57
Suspension & Brakes
Jan 8, 2005 07:17 PM
Mr.Rab
Aug 18, 2002 10:20 PM
