Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Alignment Rack Question
Old Aug 29, 2002 | 10:44 AM
Todd00's Avatar
I said I don't want a title!
Default Alignment Rack Question
I got my alignment report back on my car. Now, is -1/8 toe out or toe in? I requested toe out in the front, and by the printout and the results, I'm having a tough time telling what is what. Before it went in car was 1/32 on both sides in the front for toe. Now it came back -1/16 on both sides (for an eighth total).
Car doesn't seem to turn as well either. I'm having a hard time figuring out why going from toe-in in the front to toe-out would make the car more difficult to turn and not seem to handle as well.
Any thoughts?
Old Aug 29, 2002 | 10:55 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Alignment Rack Question (Todd00)
anything - is toe in. you should have the opposite amount of toe, (i run the same settings) +1/8 total toe out, not toe in. the reason it doesn't turn in as well is your tires are facing towards each other, kinda fighting each other. sounds like you need to go back and have them correct the problem.
Old Aug 29, 2002 | 11:39 AM
Warren's Avatar
Wrong-Way Wang
negative toe = toe out
You can call the shop and ask to talk to te alignment tech if you like.
Warren
Old Aug 29, 2002 | 11:52 AM
Todd00's Avatar
Default Re: Alignment Rack Question (Warren)
yeah, the dude at the shop said that -1/8 total was toe-out on their machine.
Maybe I should have went with more toe-out....
Old Aug 29, 2002 | 03:02 PM
Trickturn's Avatar
I've been on a couple of different alignment machines that were different. Why cant they just stick to one way??
+ being - & - being + Some read fractions other read decimals i.e. 1/16 or .0625
Definitely make sure that is what the machine says.
Pete
Old Aug 29, 2002 | 04:40 PM
jasyatz's Avatar
Default Re: Alignment Rack Question (rodney)
Every Hunter machine I've worked on, (-) is toe out.
I used to set them up with fractions, but prefer a decimal.. I think it's more exact due to the fluctuations in the machine if you "breathe" on it...
Jeff
Old Aug 29, 2002 | 07:25 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
I've heard the opposite. But not 100% sure if it is correct tho.
At turn in, the outside front tire would be most loaded, so if you have toe in, that tire would be pointing slightly towards the turn --- better turn in.
At track out, the outside rear tire would be most loaded, so if you have toe out, that tire would be pointing slightly away from the turn --- oversteer.
For the Integra/Civic, the front suspenion gains toe out as it compresses. So having a static toe in would balance that out.
Old Aug 29, 2002 | 08:02 PM
Mike P.'s Avatar
25 Year Member
Default Re: Alignment Rack Question (Wai)
Actually, due to Ackerman angles designed into the car, the outside tire would be pointing slightly less towards the turn. Toe out is automatic once the steering wheel is turned.
My guess as to why a little toe-out helps with turn-in is that the outside, more heavily loaded tire is better able to use it's traction circle by turning with less of a slip angle at the same speed than that of a car with more toe-in.
Like I said before, this is nothing but a theory. If anyone else has more knowledge on the subject of Ackerman angles, and how these angles combined with toe alignment affects handling, I'd love to hear it.
[Modified by Mike P., 12:03 AM 8/30/2002]
Old Aug 30, 2002 | 12:02 PM
Warren's Avatar
Wrong-Way Wang
In the realy real world, toe out helps turn in. Toe in = understeer city. The outside tire travels a larger arc, unless you're spinning like a top about that corner.
I can't believe someone said toe in helps turn in
Warren
chewtext
Suspension & Brakes
Sep 15, 2005 08:59 AM
scoobyghost
Aug 17, 2003 07:28 AM
SlapSmak
Jul 18, 2003 06:19 PM
