Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Adjusting front Upper Control arms
Old Jun 5, 2002 | 07:56 PM
Chris's Avatar
Default Adjusting front Upper Control arms
Sorry to beat this to death, but I am confused..
I have a 2000 ITR and STOCK suspension except for the uppers.
Before adjusting the camber I just went ahead and measured it.. I calibrated the camber guage (dial and bubble..against a known plumb wall.. old school)
I got -2 RF and -7 LF.. how can I be at -7 when the skunks only allow for +/-4?? I KNOW what -7 would look like and this IS NOT looking like -7.
Tire pressures are the same, car is close enough to level... suspension is loaded(and on the ground) when I measured. I also drove the car 10 feet forward and 10 feet back to settle the suspension.
Any thoughts?
Old Jun 5, 2002 | 08:10 PM
DB2-R81's Avatar
25 Year Member
Default Re: Adjusting front Upper Control arms (Chris)
Are you resting or attaching the gauge against your wheel or your hub?
[Modified by DB1-R81, 9:11 PM 6/5/2002]
Old Jun 5, 2002 | 08:30 PM
Chris's Avatar
Default Re: Adjusting front Upper Control arms (DB1-R81)
Rim. On the lip of the rim. I made some standoffs to clear the tire, but I made sure its calibrated with those on.. and there was no difference...
Old Jun 6, 2002 | 12:38 PM
Chris's Avatar
Any other ideas?
Old Jun 6, 2002 | 01:12 PM
Ausmith's Avatar
There is no way you have -7 degrees of camber on the front wheel.
Perhaps the surface is not level like you assume...
Find someone local that has a digital gauge that can be calibrated...
Old Jun 6, 2002 | 01:28 PM
Chris's Avatar
Default Re: Adjusting front Upper Control arms (Ausmith)
I just made an appointment with a local alignment shop.. Let them got me on the right path...
Thanks.
Old Jun 6, 2002 | 01:35 PM
Ausmith's Avatar
Good choice
It's worth the $50 every time.
Super7's Avatar
You should find a shop that will set in with you in the car.
Honda knowledge
Apr 15, 2015 10:41 AM
whiskaz
Jun 20, 2009 06:56 PM
Blamm!!
Apr 7, 2008 04:34 AM
Type R1
Apr 24, 2002 05:14 PM
